STD Tuning Engine 72mm impeller waterpump on OM603
06-02-2013, 02:29 PM #1
Hi!
Is the 72mm impeller water pump & water pump housing the same as used on the 3.5l OM603? I want to upgrade cooling a little...
Resp. does OM606 turbo water pump housing fit OM603 block? I think the blocks are essentially the same, mostly?
Thanks!
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Hi!
Thanks!
SurfRodder
Jackass Extraordinaire
611
06-03-2013, 02:41 PM #2
(06-02-2013, 02:29 PM)DiseaselWeasel Hi!
Thanks!
you could likely order a gasket for both to be sure, but that is my impression as well.
edit: looks like the same one:
http://www.autohausaz.com/search/product...16@Cooling System&gid=2148@Water Pump Gasket
edit2: well, looks like those links are bunk (if you copy the whole thing and paste, it should work)... at any rate 1997 300d and 1991 350sdl show the same part# 6012010380 for the water pump gasket...so physically it should work...
This post was last modified: 06-03-2013, 03:50 PM by SurfRodder.
OBK# 62
SurfRodder
Thanks!
OBK# 62
