to "M pump" or not
to "M pump" or not
hi guys
I've been struggling with my MW pump for so long
so finally I have to give up as I have found very good
used M pump from euro w123 300d n/a. (88hp rated)
with pump I have also fuel lines and variator with shaft so
the oiling of the pump will be direct not external like MW.
no alda on this one and I will adopt VCV to new M pump
(some kind of bracket or so...)
what is the downside of using unmodified M pump
on 617 turbo engine? will I loose power?
thanks
ChO
You will probably lose power. If you remove the aneroid (altitude capsule) form the top of the IP you may gain some back. Dieselmenken of course can get you more fuel than you would ever need
(06-06-2013, 04:26 AM)cho hi guys
thanks
ChO
thanks
ChO
(06-06-2013, 02:53 PM)OM616 Could you provide some details as to your struggles with the MW Pump?? Is it damaged and not working properly, or have you been unable to tune it as you like?
(06-06-2013, 10:02 AM)Simpler=Better You will probably lose power. If you remove the aneroid (altitude capsule) form the top of the IP you may gain some back. Dieselmenken of course can get you more fuel than you would ever need
(06-08-2013, 01:19 PM)OM616 Is this an automatic trans car??
(06-09-2013, 06:51 AM)cho(06-08-2013, 01:19 PM)OM616 Is this an automatic trans car??
yes it is...( I have 5 spd manual complete set for it however,...)
(06-10-2013, 01:51 PM)OM616(06-09-2013, 06:51 AM)cho(06-08-2013, 01:19 PM)OM616 Is this an automatic trans car??
That is why I asked, more than one of these cars have been converted...
Before you go and start changing pumps, perhaps you could indulge me in some Q&A....
First, the regulator the Bosch teck was talking about is probably the Accumulator valve vacuum controller, it plays a critical role in the proper operation of the transmission.
Do you know how many inches of Mercury your vacuum system is pulling at idle?
Do you know what the boost reading is at the ALDA?
Do you know if the Bowden (throttle pressure) cable is adjusted properly?
Does the car still behave as you describe if manually shifted?
Could be a fuel lift-pump/fuel pressure/fuel restriction issue....
(06-11-2013, 06:55 AM)Alastair E Could be a fuel lift-pump/fuel pressure/fuel restriction issue....
(06-10-2013, 01:51 PM)OM616 Does the car still behave as you describe if manually shifted?
Have you actually Checked the Pressure At The Inlet to the Pump Gallery, or at the Outlet to Return?
Ive known some new (Old and new type) lift-pumps be faulty out the box!....
(06-12-2013, 09:43 AM)Alastair E Have you actually Checked the Pressure At The Inlet to the Pump Gallery, or at the Outlet to Return?
(06-11-2013, 08:01 AM)cho(06-10-2013, 01:51 PM)OM616 Does the car still behave as you describe if manually shifted?
I dont shift manually...what I can do as a test?
(06-13-2013, 11:16 AM)OM616 EDIT: Just had a thought.... Is the EGR system still on the engine?
(06-14-2013, 02:20 AM)cho(06-13-2013, 11:16 AM)OM616 EDIT: Just had a thought.... Is the EGR system still on the engine?
616 thanks for trans procedure I will try it during the weekend..
EGR is removed/lines blocked 1.5 yr ago,intake has been cleaned before
banjo bolt to ALDA also....
EDIT: ok,tested and no power gap while on manual,with auto I have some minor flare,manual I have none.
better pedal response too.
(06-21-2013, 05:57 PM)OM616(06-14-2013, 02:20 AM)cho(06-13-2013, 11:16 AM)OM616 EDIT: Just had a thought.... Is the EGR system still on the engine?
Sorry, missed your post..
If the car runs properly when you shift it manually then you have a trans problem of some sort. Either it is not down shifting properly, is up shifting too soon, or is dragging a gear (not totally disengaging one of the clutch packs).
At least you are making some progress. If it was the pump, it would have the power loss regardless of manual or automatic shifting. That was the reason for the test.
