617 water pump
617 water pump
Anyone got links to where a 617's water pump is? Is it down in by the crank?
I seen something wobbling down there in my car and I sure hope it wasnt the crank wobbling.
Ok not the water pump, not the crank but kinda the crank. I tried to take a video but it was useless, too tight of a space.
The crank pulley and harmonic balancer are turning nice and smooth.
There is something maybe a seal? behind the harmonic balancer that's wobbly looking.
hmm, time bomb
http://www.peachparts.com/shopforum/dies...l-pan.html
Time bomb with a short fuse. Rent a puller and get in there
Best case, it's the pulley on the balancer coming apart. worst case it's backed out and chewed up the pressed pins
I will keep ya'll posted but I think it is just the seal and grease/dirt wobbling around. I think I try some oil addative to treat seals. Swell it up a bit maybe
