STD Tuning Engine m112 supercharger mounting(have i went mad)
mantahead
06-27-2013, 05:58 AM #1
hi,
i have come back to my supercharger mounting again.
the m112 is too long to fit under the inlet manifold with the engine mount and chassis will be too close to pipework, and i don't want to move my power steering pump.
was toying with this idea, have i went mad. should fit above the steering pump.
[Image: SU1HMDE3MjAtMjAxMzA2MjYtMTgxMi5qcGc_zpse6a7613f.jpg]
[Image: SU1HMDE3MTktMjAxMzA2MjYtMTgxMi5qcGc_zps78a4dee3.jpg]
either turn the manifold upside down too leave room for the charger or just put the charger on top, either way something is going to peep out through the bonnet.
mantahead
hi,
06-27-2013, 07:56 AM #2
I would more the power steering pump, or get an alecrtic unit (but that's just me).
If anything is sticking up it better be the supercharger, nothing says mad max quite like that.
mantahead
06-27-2013, 08:56 AM #3
(06-27-2013, 07:56 AM)Simpler=Better I would more the power steering pump, or get an alecrtic unit (but that's just me).
like this then.
either on top of the rocker cover or the manifold.
[Image: SU1HMDE3MjctMjAxMzA2MjctMTE0OC5qcGc_zps1ec76551.jpg]
[Image: SU1HMDE3MjItMjAxMzA2MjctMTE0Ny5qcGc_zpsb005e2d0.jpg]
[Image: SU1HMDE3MjMtMjAxMzA2MjctMTE0Ny5qcGc_zpsab388401.jpg]
Is it better to keep the charger flat or on its side for the oil inside?
i know very little about chargers to be honest.
i can rotate it any way up there as i have plenty of room.
mantahead
like this then.
06-27-2013, 01:32 PM #4
I would mount it on the manifold, and add support to the manifold somehow. That way you can get at the injectors/ valve cover if there is a problem
06-27-2013, 02:15 PM #5
Make a custom intake manifold. I would cut the manifold like 4-6 inches off the head and mount the supercharger directly to the head.
This post was last modified: 06-27-2013, 02:21 PM by willbhere4u.
OM616
10mm MW
574
06-27-2013, 02:48 PM #6
You can mount the blower in any clocking orientation as long as the rotors are horizontal. However, make note of the oil level check screw, depending on the OEM position, (yours was most likely sitting on the outlet), so depending on how you position it, you will have to fill the oil with the blower off, or put a new fill port in the nose cover that allows you to fill and check the gear oil...
Just in case you did not know, the air flows in from the back end of the blower and out the bottom.
I think I posed pics of an Eaton M90 that I shortened the drive snout on in a different thread..
Oh, another thing, most likely there is a spring loaded dampener between the input (pulley) shaft and the rotor gear.. They tend to fail as they get old and if you look on e-bay, you can get a rubber coupling to replace the squishy spring one. You can tell if yours has the spring one by holding the rotors and trying to rotate the pulley back and forth, one way will be solid, the other way the pulley will turn and you will feel the torsion spring winding up.
OM616
swecias
HX40Super
40
06-27-2013, 05:48 PM #7
here how I do that Smile
swecias
mantahead
06-27-2013, 05:56 PM #8
(06-27-2013, 05:48 PM)swecias here how I do that Smile
cheers,
that is m112?
how you going to extend crank pulley?
have you room with radiator?
This post was last modified: 06-27-2013, 05:57 PM by mantahead.
mantahead
cheers,
that is m112?
06-28-2013, 07:05 AM #9
hy there,
i am curious why u whant to use a supercharger in a diesel engine?
could u make some light to me?
any how if is your intention to use the super charger to precharge a huge turbo, u still have to make a way of cooling the air, as i see things u could put it anyway where u got space.
Just another question , your oil radiator is OEM or is it a MOD?
hy there,
mantahead
06-28-2013, 07:27 AM #10
(06-28-2013, 07:05 AM)barrote hy there,
hi,
yea to help spool the turbo.
not sure about what swecias' oil cooler is off, looks bigger than oem.
mantahead
hi,
06-28-2013, 10:08 AM #11
Hy there,
Recently i had to "change " one oil filter assy in order to bolt in pipes instead of having the oil to water cooler, it was easy doing. i just couldn´t find oil filter assy for oil to air coller conections in Portugal, even in old merc. all i found was water to oil coolers , that was my question.
Now that i understand the charger issue, i would put it right above the turbo, built a base for it . it wold discharge right to the turbo inlet , more less curve and u still have place for a buterfly valve once the charger mass limit is reached, open a hole in the hood for charger breadingSmile
if u look at the principle of a low ratio turbofan engine , (thats what we call aviation engines) the compressor usually benefits from "ram" efect, this hapens when the inlet pressure is above 1. well the thing is an airplane moves through the air with the compressor inlet exposed to this "ram" effect once the A/P reaches a certain speed.
So u will benefit from pressurizing the turbo with the charger at low rev , but what are u inteding to do when this inlet pressure drops below 1? that will happen from 2/3 k on , i m sure the turbo will suck a lot more air than the charger will be able to pressurize.
we should never forguet that air is a compressible fluid.
regards
FD
Hy there,
regards
FD
erling66
SuperDieselVan
294
06-28-2013, 10:52 AM #12
What about straighten up the engine a bit? Should not hit the hood and you have enough room on the left side. Then you can mount the turbo quite low and you will have room for the blower on top of the turbo without hitting the hood.
HuhCoolTongue
erling66
HuhCoolTongue
mantahead
07-01-2013, 04:32 AM #13
hi,
i would need to get a turbo to see how much room i have.
is there a crank pulley available with extended piece for another belt, i want to run the charger off its own belt or will i have to make one?
(06-27-2013, 02:48 PM)OM616 You can mount the blower in any clocking orientation as long as the rotors are horizontal. However, make note of the oil level check screw, depending on the OEM position, (yours was most likely sitting on the outlet), so depending on how you position it, you will have to fill the oil with the blower off, or put a new fill port in the nose cover that allows you to fill and check the gear oil...
yea, there seems to be that spring loaded dampener on mine.
any links to a rubber coupler?
This post was last modified: 07-01-2013, 04:34 AM by mantahead.
mantahead
hi,
yankneck696
395
07-01-2013, 07:28 AM #14
Look up "Crazy Carl Whipple " for how it was done on a 24 valve Cummins. His wild creations should give you some inspiration & palpatations...
Ed
yankneck696
Ed
OM616
10mm MW
574
07-01-2013, 07:33 PM #15
(07-01-2013, 04:32 AM)mantahead yea, there seems to be that spring loaded dampener on mine.
http://www.ebay.com/itm/Eaton-GM-Ford-Me...409wt_1137
There are also some listed that come with the oil, and some with bearings and the oil.
OM616
bricktron
'77 240D
174
07-02-2013, 12:57 AM #16
(06-28-2013, 10:08 AM)barrote from 2/3 k on , i m sure the turbo will suck a lot more air than the charger will be able to pressurize.
this is worth looking into!
bricktron
mantahead
07-02-2013, 04:13 AM #17
(07-01-2013, 07:28 AM)yankneck696 Look up "Crazy Carl Whipple " for how it was done on a 24 valve Cummins. His wild creations should give you some inspiration & palpatations...
Ed
yea,
i was talking to this guy on competition diesel, seems to have tried everything with superchargers and turbos. nice guy.
(07-01-2013, 07:33 PM)OM616
thanks for that om616.
(07-02-2013, 12:57 AM)bricktron
yea,
i will make a divertor flap.
This post was last modified: 07-02-2013, 04:15 AM by mantahead.
mantahead
Ed
yea,
yea,
07-02-2013, 05:04 AM #18
yep, maybe u should consider finding an air conditioner puley clutch to kill the compressor when u reach the value of one at the compressor inlet Smile , i think is easy for u to do that.
keep us updated on the progresso.
regards
FD
regards
FD
mantahead
07-02-2013, 05:15 AM #19
(07-02-2013, 05:04 AM)barrote yep, maybe u should consider finding an air conditioner puley clutch to kill the compressor when u reach the value of one at the compressor inlet Smile , i think is easy for u to do that.
regards
FD
yea,
would be a good idea but that pulley is so small and can't make it bigger or charger would be slower.
anyone know if there is a 3 inch clutch pulley available, or smaller?
This post was last modified: 07-02-2013, 05:31 AM by mantahead.
mantahead
regards
FD
yea,
07-02-2013, 09:33 AM #20
check this out a small pulley with a clutch http://www.sl-i.net/FORUM/viewtopic.php?f=59&p=180988
mantahead
07-02-2013, 06:13 PM #21
(07-02-2013, 09:33 AM)willbhere4u check this out a small pulley with a clutch http://www.sl-i.net/FORUM/viewtopic.php?f=59&p=180988
thanks for that.
mantahead
thanks for that.
07-03-2013, 10:13 AM #22
Saw that awhile back while building a WRX and thought that was a nifty idea
swecias
HX40Super
40
01-01-2014, 06:46 AM #23
(06-27-2013, 05:56 PM)mantahead
cheers,
that is m112?
here you go
swecias
cheers,
that is m112?
here you go
mantahead
01-01-2014, 12:31 PM #24
cheers for that, i have mine made also.
[Image: 10106031785_94b11956a3.jpg]
Lisburn-20131005-00639.jpg by mantahead, on Flickr
mantahead
swecias
HX40Super
40
01-02-2014, 04:51 PM #25
(01-01-2014, 12:31 PM)mantahead cheers for that, i have mine made also.
you dont thing that belt will slip with that belt ? Smile how much rows is it ?
swecias
mantahead
01-02-2014, 06:01 PM #26
shouldn't slip with plenty of belt wrap, its 8 rib.
did you get your charger mounted yet, did you shorten the snout?
This post was last modified: 01-02-2014, 06:03 PM by mantahead.
mantahead
