STD Tuning Engine Rear main seal lessons
Torkey
Dirty Diesel
220
07-01-2013, 01:46 PM #1
I wanted to share the knowledge from a long hard lesson we learned on our 617.
We did a rebuild of our engine over the winter and replaced the rear main seal. We eventually replaced it three more times after repeated failures.
A local machine shop mentioned that they have had problem with the newer rope seals because they no longer make them out of asbestos.
Fortunately, the original Mercedes part is asbestos. And we were surprised to find out when it arrived that it the dimensions are different from the other seals we tried. Approximately .02" thicker in height and width of the cross section.
So if you are having problems with your rear main seal. Try the original Mercedes part.
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
07-01-2013, 04:22 PM #2
good to know
good to know
07-02-2013, 08:01 AM #3
Did you sniff the asbestos seal before putting it in?
This is a great example of why banning materials from all applications isn't the best solution. Pipe insulation where it might flake off near a ventilation system? Definitely ban it.
In a car where it will be bathed in oil and contained? Don't ban it cmon' guys
Torkey
Dirty Diesel
220
07-02-2013, 03:40 PM #4
(07-02-2013, 08:01 AM)Simpler=Better Did you sniff the asbestos seal before putting it in?
Funny the thought of smelling it never crossed my mind. Tongue
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
07-05-2013, 05:43 PM #5
Are you telling me that I shouldn't have stuffed my pillow with asbestos? Huh
Didn't want my head catching on fire in the middle of the night Wink
