STD Tuning Engine Alternatives to the plastic intake manifold on OM605
Eric78
07-07-2013, 02:53 AM #1
Only just realised yesterday that the intake manifold & crossover pipe on this engine are plastic, I'm guessing these won't withstand big turbos, so what are the alternatives?
Eric78
mantahead
07-07-2013, 06:55 AM #2
(07-07-2013, 02:53 AM)Eric78 Only just realised yesterday that the intake manifold & crossover pipe on this engine are plastic, I'm guessing these won't withstand big turbos, so what are the alternatives?
you can use aluminium 6 cylinder manifold and cut one port off.
mantahead
Mark_M
07-07-2013, 10:48 AM #3
The plastic intakes are actually pretty damn strong and don't conduct the heat anything like as much so I wouldn't dismiss it just because it's plastic. Course it depends how far your going and if you need to change the shape at all.
Mark_M
Eric78
07-08-2013, 12:26 AM #4
(07-07-2013, 10:48 AM)Mark_M The plastic intakes are actually pretty damn strong and don't conduct the heat anything like as much so I wouldn't dismiss it just because it's plastic.
Not sure if the plenum is big enough though, I have an HX35 & an HX52, I've been considering using them together in compound, but might use just the HX35.
(07-07-2013, 06:55 AM)mantahead you can use aluminium 6 cylinder manifold and cut one port off.
Anything to do with the 606 will be harder to get here than this engine was.
This post was last modified: 07-08-2013, 12:27 AM by Eric78.
Eric78
EDH_Performance
07-08-2013, 01:55 AM #5
(07-07-2013, 10:48 AM)Mark_M The plastic intakes are actually pretty damn strong and don't conduct the heat anything like as much so I wouldn't dismiss it just because it's plastic. Course it depends how far your going and if you need to change the shape at all.
Do you think it can handle 3bars?
EDH_Performance
07-08-2013, 08:21 AM #6
You can always trace a gasket onto some aluminum and make a plenum Smile
Mark_M
07-08-2013, 06:12 PM #7
(07-08-2013, 01:55 AM)EDH_Performance
Your the man that can find out Big Grin
If it wasn't such a pain to seal all the holes I would pressure test mine because I can't use it anyway.
If you cant get a 606 inlet and you need it to be alloy then I think you will have to make your own.
Mark_M
EDH_Performance
07-09-2013, 01:52 AM #8
(07-08-2013, 06:12 PM)Mark_M
It will be tested in my 250tdt dailydriver! It looks like a good and strong casting, so let`s hope it dont seperate...
EDH_Performance
dieselmeken
07-09-2013, 02:09 AM #9
(07-09-2013, 01:52 AM)EDH_Performance It will be tested in my 250tdt dailydriver! It looks like a good and strong casting, so let`s hope it dont seperate...
With that pump im sure the engine will separet before the inlet manifold....
dieselmeken
EDH_Performance
07-09-2013, 02:57 AM #10
(07-09-2013, 02:09 AM)dieselmeken
Hoho, not when my holset HE300WG pushing 4 bars easily! Big Grin
EDH_Performance
