STD Tuning Engine Removing Oil Thermostat
Torkey
Dirty Diesel
220
07-13-2013, 10:31 AM #1
I'm considering removing the oil thermostat out of the oil filter housing.
The reason I am considering it is because this is an endurance race car and if it failed not having the oil cooler would be a significant issue.
Has anyone done this before?
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
AlanMcR
mind - blown
400
07-14-2013, 09:16 AM #2
How many of these fail, ever?
Also, you may find that the design uses the thermostat to direct flow, thus without the thermostat only a fraction of the flow goes the long way out to the cooler.
AlanMcR
poleshady
07-14-2013, 03:41 PM #3
In one of my cars, it failed. the oil cooler never got hot, or even warm.
poleshady
OM616
10mm MW
574
07-14-2013, 03:51 PM #4
Do you want the oil to always flow through the cooler?
I had mine all apart when I modified it for my 201 project. I do not see why the thermostat could not be removed and a part machined up that simulated the thermostat in cooling mode and installed so as far as engine knows the thermostat is still there.
OM616
Torkey
Dirty Diesel
220
07-14-2013, 07:21 PM #5
(07-14-2013, 03:51 PM)OM616 Do you want the oil to always flow through the cooler?
Yes, we were thinking of having the oil always going to the cooler.
If if failed shut during a race it would be bad for us.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
OM616
10mm MW
574
07-14-2013, 08:04 PM #6
I would make a new piece to replace the thermostat then, that way the system is working how it was designed to (no surprises), and it eliminates your concern.
The thermostat screws in, and as I recall it took a bit of torque to brake it loose.
OM616
07-15-2013, 08:48 AM #7
Make sure you're monitoring oil temp too
07-16-2013, 10:37 AM #8
The oil filter housing I removed from an '85 motor to mod for an engine swap didn't work.
The oil not reaching operating temps is also not a good thing. Were it my car, I would monitor oil temps and make repairs as necessary.
07-16-2013, 12:05 PM #9
Here's a dumb question. The oil without any thermostat should reach at least 180-200 F no matter what. If that assumption is correct, then why would that be bad ?
