om602 hx35 boost problem
I'm currently using an OM602 superpump with 140cc 7.5 element with a HX35.
The probleme is i can't only get the hx35 to boost 8-7 psi at 1st gear 10-12 at second gear and 16-18 at 3rd gear.
I disconnected the wastegate so it won't open. Did a pressure leak test. Timing is good. Injector are rebuilt.
So what could be the problem? would the HX35 just be to big to spool? would an HY35 be better with is small exhaust housing?
(07-15-2013, 10:48 AM)cover240sx I'm currently using an OM602 superpump with 140cc 7.5 element with a HX35.
Probably should make sure the wastegate is completely closed, even the smallest crack and you can lose all your drive pressure.
What housing is on it?
You can always try a HY35 swap out real quick. Direct replacement. Everything is the same for mounting & lines.
Ed
Just to bump this thread again
Im running 2.1 BAR with mine, exhaust pressure before turbine is 2.4 BAR
Comes on full boost about 3700-4000.
Again i have a big H1C with a .63A/R
the HX35 use a 12cm housing. tryed touse an HY35 with 9cm but still nearly no boost and I did a leak test and no leak to be found. I really don't know what could be the problem. I'm usin a 3" straight exhaust so it shouldn't have a lot of backpressure
(08-02-2013, 10:04 AM)Joaquin SuaveQuote:Just to bump this thread again
Duncan, would you be kind enough to share a picture of the turbo on your OM602?
Thanks in advance.
J.S.
I bet its a leak. The first two times out my car would only make 12 psi, Couldnt hear or see a leak. I pressurized the system to 40psi and found a coupler leaking. After fixing that the car was doing 35psi and blowing the remaining not t-clamp fittings off.
Its not as complicated as your making it.
You need to know you turbine inlet pressure to really diagnose this.
Thanks in advance.
J.S.
If the low idle screw is adjusted cw = lower rpm on low idle, and you adjust up the idle speed with the throttle shaft you get low power.
I have had some customers that have done this adjustments and lost power that way.
Scenario is, start up engine and low idle is to high, 1500-1800rpm, low idle adjusts down on the 6 mm screw on the governor, = power is lost.
Fault is that the throttle not goes back to zero in the linkage.
Always check linkage before you adjust on the pump.
Can this be your problem or have you solved it?
(08-05-2013, 11:19 AM)dieselmeken If the low idle screw is adjusted cw = lower rpm on low idle, and you adjust up the idle speed with the throttle shaft you get low power.
