Busted 2 thermostat housing bolts!
You're lucky, up in Canadia you have metric stuff in every hardware store! Regular bolts will be fine, add some neversieze or grease to them. If you're loaded($$) use brass studs with mild steel nuts.
I had broken off 1 or 2 of the original stock bolts, they came out pretty easy with a screw remover or something as I recall.
To be clear, the bolts I broke were the ones that hold the 2 halves of the housing together.
