STD Maintenance General Anybody know what this box is?
dieselsmoke300d
To many things I say: Bah Humbug!
65
07-18-2013, 05:42 PM #1
I found it under a panel by the passenger door in the '85 300SD I just bought. I googled it and came up with nothing. Is it something emissions related?
[Image: 20130718_183434.jpg]
Matt.
'85 300SD Turbo
'92 Subaru SVX
'83 Pontiac Firebird S/E
'88 Pontiac Firebird
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
07-18-2013, 07:06 PM #2
that egr label sure sounds like emissions Wink
Does that thing open up? Maybe there is some electric or vacuum control shit in there.
http://lmgtfy.com/?q=0025456032
This post was last modified: 07-18-2013, 07:08 PM by larsalan.
Austincarnut
07-18-2013, 08:52 PM #3
(07-18-2013, 05:42 PM)dieselsmoke300d I found it under a panel by the passenger door in the '85 300SD I just bought. I googled it and came up with nothing. Is it something emissions related?
EGR computer
Austincarnut
EGR computer
07-19-2013, 08:04 AM #4
Don't trash it just yet, I remember hearing somewhere that this can be used to wire up a tachometer
Austincarnut
07-19-2013, 09:51 PM #5
(07-19-2013, 08:04 AM)Simpler=Better Don't trash it just yet, I remember hearing somewhere that this can be used to wire up a tachometer
'85 should have a tach
Austincarnut
dieselsmoke300d
65
07-21-2013, 10:33 PM #6
Well I ran the numbers and apparently it's the cruise/engine control module. I don't know why it has EGR on it.
Matt.
'85 300SD Turbo
'92 Subaru SVX
dieselsmoke300d
Matt.
'85 300SD Turbo
'92 Subaru SVX
07-22-2013, 06:18 AM #7
I think your part is pictured here...
http://www.peachparts.com/shopforum/dies...lated.html
In post #3 as part labeled '80'
w123love
Stockish
354
07-22-2013, 09:32 PM #8
On 85 models it has a tach computer in it as well as EGR function. The 85's use two tach inputs, one on the transmission and another on a normal spot (where ever that is). Your tach won't work if you take it out. You can disable the EGR at the source and have no issues.
The VEGEWGN
w123love
The VEGEWGN
Austincarnut
07-22-2013, 10:05 PM #9
(07-22-2013, 09:32 PM)w123love On 85 models it has a tach computer in it as well as EGR function. The 85's use two tach inputs, one on the transmission and another on a normal spot (where ever that is). Your tach won't work if you take it out. You can disable the EGR at the source and have no issues.
the 'normal' spot is for test only, the tach signal is taken from ring gear teeth by sensor on trans adapter. the engine in '85 or california is prewired for the older style tach but no tach amp or wiring from plug
Austincarnut
