606 top end rebuild
606 top end rebuild
I'm rebuilding a 606 for my G wagon desert racer G wagon project.
Head (100K Miles prior to dissssembly) is stripped ready to go off for porting work and I plan to replace springs and seals when I rebuild.
I'm unsure whether it is also worth full new set of valves and recutting at the same time? The valves aren't cheap, but given all the other work I am doing, perhaps it is better to be sure?
Does anyone have experience with this?
(07-24-2013, 03:33 PM)fcp I'm rebuilding a 606 for my G wagon desert racer G wagon project.
don`t need new valves, but you need new springs
kmcams.com is the way to go
Anyone cant say replace or not the valves as seen those.
Really good Pro Performansce valve spring kits are available in
tarvikemotti.com
Proven to hold huge power
(07-27-2013, 03:03 PM)jeemu Anyone cant say replace or not the valves as seen those.
tarvikemotti.com
