STD Tuning Brakes Whats the weight difference between the cast itron 4 pots and aluminum ones?
08-26-2013, 07:11 AM #1
Is there really that much difference? The cast iron ones are pretty heavy, and the 4 pot aluminums off the w220 (relabeled brembos?) can be had relatively cheap.
08-26-2013, 11:00 AM #2
http://www.w124performance.com/images/W1...brakes.pdf
Page 5, "weight", should give some insight. It lists the 500e brembo 4pot caliper.
atypicalguy
12-27-2018, 11:53 PM #3
(08-26-2013, 11:00 AM)raysorenson http://www.w124performance.com/images/W1...brakes.pdf
This difference is quite large. The aluminum brembo 300mm fronts are super light compared to the 334s
atypicalguy
