basket behind vacuum pump, different om601-606?
hello, looking for the "basket" that is behind the vacuum pump
is it the same in a om601 as in a om603/om606?
Early engines came with a basket in them. Mine's still in there. You've got to use an early vacuum pump gasket if you leave it in there.
(09-17-2013, 05:37 PM)raysorenson Early engines came with a basket in them. Mine's still in there. You've got to use an early vacuum pump gasket if you leave it in there.
Those crappy little pieces of sheet metal cost over 400 USD. Definitely worth making one yourself.
I would appreciate getting a copy of your drawing.
There are three of us with OM60X engines. Chances are we'll need to pull an IP sooner or later. Not sure what the chances are that the first one will have a basket.
Thank you.
as long as they are the same regardless of om60x engine
was recomended to put one in when changing pumps, and bought one for the reasonable price of 10$ from a guy that got it from his torn om601, shure is hoping that it fits
and yeah, a drawing with dimensions to make one myself would be awsome to!
doesnt have a plan to leave it in, just to change pumps safe
thanks!
