STD Maintenance General Ever Seen This? Broken Pre Chamber...
09-23-2013, 12:54 AM #1
In light of the Prechamber Mod "Flame" Front thread, http://www.superturbodiesel.com/std/thread-2169.html , I finally gathered the tools and pulled all the pre-chambers out of the 1985 head that I have. All came out easily and I had removed the glow plugs just prior. I was super stoked to see that the '85 had the "Up rated" prechambers with the larger "k" and "L" holes
I got sad though when I pulled #5 chamber and saw it was broken...
Has anyone ever seen this?
Guess I'm back to pulling my current chambers and reaming them, But looks like a lot more reaming is to be done to the up rated chambers anyway!
09-23-2013, 06:29 AM #2
Yes. Common issue... Makes a lovely noise Wink In worse cases the "swirl pin" (don't know the proper english term) cracks open the pre-chamber and creates serious damage to the engine...
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
09-25-2013, 08:33 AM #3
Better than this (thanks to autolite):
[Image: prechamber1.jpg] [Image: prechamber2.jpg] [Image: prechamber3.jpg]
09-25-2013, 09:56 AM #4
Dunno if you recalled the glow plugs I pulled from my first motor winmutt, but the ends were all gone and I was scared of things looking like those
carlitosgy6
Ranger Turbodiesel
144
12-20-2013, 07:32 PM #5
(09-25-2013, 08:33 AM)winmutt Better than this (thanks to autolite):
please explain how glow plugs caused that,thanks in advance
carlitosgy6
Austincarnut
12-21-2013, 09:47 AM #6
I've seen it, it killed 2 cyl on an engine I had. The turbo was junk also, engine still ran fine...
(09-23-2013, 12:54 AM)Captain America In light of the Prechamber Mod "Flame" Front thread, http://www.superturbodiesel.com/std/thread-2169.html , I finally gathered the tools and pulled all the pre-chambers out of the 1985 head that I have. All came out easily and I had removed the glow plugs just prior. I was super stoked to see that the '85 had the "Up rated" prechambers with the larger "k" and "L" holes
Austincarnut
12-21-2013, 03:54 PM #7
(12-20-2013, 07:32 PM)carlitosgy6
Tips break off and the injection repeeatedly slams the tip against the end of the chmaber ateast 10x per second
carlitosgy6
Ranger Turbodiesel
144
12-24-2013, 07:33 AM #8
Thanks for your info
carlitosgy6
