STD Tuning Engine OM606 Superturbo project.
pmj4147
T04R + TD06
42
09-28-2013, 03:20 AM #1
I'm planning about swap the engine to 606 from 602
And it's for 1/4mile drag race.
Project goals are
1. Over 500hp
2. Under 13second
3. Smash all 2litre gasoline.
Following parts will be used
1.HX40 or Garrett GTX35R
With
Eaton M90 loots charger
2. 8mm Dieselmeken IP
3. Watercooled IC
But here is the problem.....
Which engine should i buy????
There's so many 606s
962, 912, bla bla bla bla
Which engine should i buy??? And what is the difference between those variations???
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
Project goals are
1. Over 500hp
2. Under 13second
With
3. Watercooled IC
09-29-2013, 06:44 AM #2
Looks to me like anything past om606.96x is turbo'd, and before was naturally aspirated. But as far as which are fully mechanical or make the most power etc... I don't know.
What do all you 606 guys think?
09-29-2013, 09:38 AM #3
The difference is the 606 962 is turbo the .912 is NA. So better use the turbo.
Over 500hp ok. under 13sek could be. smash all 2 Litre NA not all. and 2l turbo never.
Hx40 is to small for over 500hp. dieselmeken pump no problem.
hansebanger77
09-29-2013, 09:43 PM #4
hansebanger, what is a reliable hp level for a w210?
Reliable being high horsepower, but not having to worry about axle shafts and blowing the trans to pieces
I know you'd have to beef up the 722.6
09-30-2013, 12:17 AM #5
Good question. I don't know about w210 but it shout handle good power becaus ist 177hp and good trorque in stock. Axle I think is no problem. For over 6 700nm? You should check some stuff on the gearbox ? Sorry never tryed an auto box.
hansebanger77
09-30-2013, 08:26 AM #6
(09-30-2013, 12:17 AM)hansebanger77 ... never tryed an auto box.
Good man!
Good man!
09-30-2013, 09:26 AM #7
We don't have as many choices over here in the states Big Grin
