OM617a vs. OM617
OM617a vs. OM617
My apologies.
I understand that this may be a "beaten into the dust" kind of question, but...
What in the hell is an "OM617a"?
Just when I thought I knew about Mercedes diesel engines, I hear mention of this thing.
So if somebody would please clear this up for me and others.
What is an om617a?
And how does it compare to an om617?
om617a = turbo
om617 = NA
from what i know, the turbo has oilsquirters under the pistons where the 617 dont.
(different injectionpump etc etc.)
to get your 200whp, a 617a with a 617injectionpump is probably the way to go. (+turbo IC etc)
it is cheaper and better to get different elements in the NA-pump (m-pump)
the turbo617 has a mw-pump.
The 617a (turbo) has a stronger crank, piston squirters, different cam, sodium filled exhaust valves, and a different oil pan bolt pattern. MW pump comes stock. MW pump is more sophisticated but not a lot of tuners out there.
the 617 (Naturally aspirated) has a weaker crank, no squirters, regular valves, and a different oil pan bolt pattern. M pump comes stock. many tuners for the m pump (dieselmenken comes to mind)
Also, the rods may or may not be different I don't know.
(10-17-2013, 07:53 AM)Simpler=Better ...
'Bout what I had figured. thank ya kindly.
