IP not working
IP not working
I just had a failed lift pump the other day. It could pump with no resistance but, under back pressure it couldn't do anything.
This sounds like a fuel supply issue. Clogged lines, filters, dead lift pump. Did you try to open the injector lines and crank the starter?
Another thing that can cause problems is if the tank vent it plugged, the tank can get a vacuum in it and then the pump can't pump as hard as the tank is "sucking" and cause issues
