STD Tuning Engine methods of IP timing
bricktron
'77 240D
174
11-04-2013, 02:08 PM #1
hi folks, i have the impression that there are a number of ways of setting IP timing; some of them require special tools or machines; there is also the "stupid-ass drip shit".... Heart
which one is the way you other home mechanics do it, and which way would a shop probably do it if i took the car in for this? is there a consensus in here about which method to use, or does everyone have their own favorite approach?
(PS my rationale for resetting it is excessive white smoke while warming up - picture passers-by covering their mouths and crossing the street to avoid it. the exhaust is barely noticeable once the 617 is warm. i already adjusted the valves and installed rebuilt injectors.)
bricktron
OM616
10mm MW
574
11-04-2013, 02:58 PM #2
So I will really stir up the pot here, but I measure the element plunger height to set the start of injection timing...Huh
OM616
11-04-2013, 03:44 PM #3
On our tractors I set it by ear and how it starts and if it runs correctly Wink
But isn't the drip method the "official" way to do it?
11-04-2013, 03:46 PM #4
I drip time because I'm a knuckle-dragging cretin
OM616
10mm MW
574
11-04-2013, 04:15 PM #5
(11-04-2013, 03:44 PM)MFSuper90 On our tractors I set it by ear and how it starts and if it runs correctly Wink
So you understand what it means to truly tune the engine, so many people think that a speck in a manual is best for an engine with many miles on it, running on fuel that varies greatly around the world..
I use the plunger height to set the initial timing so I know where I am starting from, then adjust by ear, EGT, and performance. Then if I ever have to remove the IP, I can see where the timing is and get it back in exactly the same place.
OM616
mantahead
11-04-2013, 05:34 PM #6
hi,
i use the dyno and adjust for max power with lowest Egt.
mantahead
hi,
Austincarnut
11-04-2013, 08:35 PM #7
drip timing is the most accurate as it is sort-of dynamic, you will actually see when the start of delivery begins and you can dial in wherever/whenever you want that to happen
Austincarnut
11-04-2013, 09:05 PM #8
I tried the drip method, couldn't get it to the 1 drip/second at 26° BTDC, so I just advanced the timing all the way. Yeah it kind of runs like crap when I start it up if it's below 75 out, but it runs fine once it's warmed up
Tito
11-05-2013, 01:18 AM #9
(11-04-2013, 08:35 PM)Austincarnut drip timing is the most accurate as it is sort-of dynamic, you will actually see when the start of delivery begins and you can dial in wherever/whenever you want that to happen
I was thinking the same thing. But how does the plunger hight method work? Just measuring the hight of the plunjers won't work because you can't see the injection start. Even with the drip method the injection is later cause of the buildup of pressure takes a some time (0.5mm or so)...
Tito
dieselmeken
11-05-2013, 02:29 AM #10
Drip method is OK if you take out the deliveryvalve plunger & spring so fuel can be primed by hand, Engine turned until fuel stops to come = Injection begin. BUT BE CAREFUL AND ASK YOURSELF; DOES THIS ELEMENT HAVE A RETARD NOTCH AT LOW IDLE? IS THE RACK AT MAX FUEL OR WHER IS IT? DOES THIS ELEMENT HAVE A NOTCH THAT SETS THE TIMING LATER AT EXCESS FUEL?
Example, You set the timing with drip method at 20 BTDC, BUT you have the element at low idle. Element have a retard notch that sets timing 2 pump degrees later. what your timing at full load then?
Today most pumps have pin timing or locking of driveshaft, that is the workshop sets the timing on the pump, ex injection start + 5,5 degree offset, set Engine to TDC and put pump in = 11 degree BTDC.
dieselmeken
11-05-2013, 03:23 AM #11
(11-04-2013, 05:34 PM)mantahead hi,
I do the same with my pulling tractor
OM616
10mm MW
574
11-05-2013, 12:08 PM #12
(11-05-2013, 01:18 AM)Tito But how does the plunger hight method work? Just measuring the hight of the plunjers won't work because you can't see the injection start. Even with the drip method the injection is later cause of the buildup of pressure takes a some time (0.5mm or so)...
First, the actual start of injection does not take place at port closure as you mentioned. Port closure is a consistent reference to time the crank to. The actually moment that the injector starts injecting fuel is affected by the viscosity of the fuel, Delivery Valves, Injector Pop Pressure.. Etc. That is why a generic speck will not yield the best performance, as, each engine, with it's own unique combination of settings and states of wear, will require the actual timing to be set to what ever suits it best, but the generic speck is a good place to start from.
As for measuring the plunger height... When an IP is built, the #1 element is set to close the fill port at a certain amount of plunger lift, (5.5mm MW has a spec, M has different ones). It is to this lift speck that I am referencing when I measure the plunger height, as it is at this point where the fill port closes (+- Assembly tolerance).
From there I adjust to what ever the engine wants...
Dieselmeken brings up an excellent point about throttle position when using the drip method. That is very important.
OM616
mantahead
11-05-2013, 03:41 PM #13
the drip method is not so bad, its really for your own reference.
i have used the drip method and checked with the timing light and they are usually both the same within 1 degree of each other.
mantahead
Duncansport
11-05-2013, 04:20 PM #14
This subject is getting way to much attention.....
<-----Let the beating begin Big Grin
Duncansport
Austincarnut
11-05-2013, 10:13 PM #15
beating?
(11-05-2013, 04:20 PM)Duncansport This subject is getting way to much attention.....
Austincarnut
beating?
Volker407
naturally aspirated
157
11-07-2013, 02:23 PM #16
LOL Big Grin
Volker407
LOL Big Grin
11-07-2013, 02:45 PM #17
(11-05-2013, 10:13 PM)Austincarnut beating?
AKA Ham Shankin'
AKA Ham Shankin'
06-20-2014, 04:59 PM #18
today i did that , been there seen it!!!
light method , took us 5 minutes, folks 5 minutes. from 20º to 18.5 what ever they say is good. FIVE minutes.
invite u fine people to find a method that takes less!!!
swampmonkey
hx40 super
280
06-20-2014, 05:33 PM #19
regarding timing, my om602 runs a tad hot, it starts good, kind of mad idle the first 10seconds, but then good...
set by that special led-electronic part that some mechanics use.
is the engine runing hot a symptom of a badly timed pump?
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
