STD Tuning Engine Challenge for STD members
300SD_KY
super turbo diesel
121
11-30-2013, 12:23 PM #1
Hemmings reported about 5-cylinder diesel engine from a w116 300SD with a few mods in the 1970s = 200 mile per hour vehicle
Challenge to DieselMeken: can you & crazy diesel performance Finns put together a package for a 2014 or 2015 Group Buy inspired by world's first 200 MPH diesel super car: http://www.hemmings.com/hmn/stories/2009...ure19.html
In time for Gatebil 2015?
300SD_KY
11-30-2013, 12:48 PM #2
I find it hard to believe they slapped a intercooler on it turned the boost up to 30psi different cam and BAM! They have 230hp.
Anybody else having trouble grasping that? All I'm missing is the cam, and I'm 100hp behind them! Haha
11-30-2013, 02:11 PM #3
Well first off, a w123 probably has like 14x as much drag as the C111, that thing also had probably 10 forward gears, and I bet it probably had like 8-10mm elements from the Bosch factory itself
11-30-2013, 02:18 PM #4
Yes, that was a om617.952a engine, but reduce most of the drag, get rid of bunch of weight, boost fuel and air ALOT, and some other tricks of the trade, and yes 200 mph. Is it just a cam and some more boost ? I highly doubt that.
300SD_KY
super turbo diesel
121
11-30-2013, 02:18 PM #5
Here's a picture of the modified 3.0 liter 5-cylinder engine bay ...
Hard to believe this 1970s turbo-charged diesel capable of 200 MPH ...
http://www.mercedesclass.net/wp-content/...884_08.jpg
300SD_KY
11-30-2013, 02:29 PM #6
Jesus, this is an article by a journalist, not by a diesel tuning guru ffs, give it a break... Smile
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
11-30-2013, 02:50 PM #7
I wonder what trans they used, and where can I get one
300SD_KY
super turbo diesel
121
11-30-2013, 04:18 PM #8
The car is on display at the Mercedes museum in Germany… Any forum members nearby?
300SD_KY
11-30-2013, 05:29 PM #9
(11-30-2013, 04:18 PM)300SD_KY The car is on display at the Mercedes museum in Germany… Any forum members nearby?
And can they please discretely steal the camshaft out of it and send it my way? Big Grin
12-01-2013, 04:11 PM #10
I read another article by a journalist that rode in an OM617 powered C111. The driver was instructed to make no sudden moves to the L or R because of all the cars on the circuit that were travelling at a much higher speed. Acceleration was weak with the 200mph gearing and a high speed was not reached on the test drive. Sounds pretty lame to me.
12-01-2013, 05:06 PM #11
So basically, they made it to 200mph, but it took a VERY long time :p
300SD_KY
super turbo diesel
121
12-01-2013, 05:15 PM #12
I wonder how many drivers make sharp turns over 125 MPH?
300SD_KY
Austincarnut
12-01-2013, 09:10 PM #13
it had dry sump, custom injection pump, mid/rear engine, low drag coefficient, overdrive, etc.... Their car did make those numbers, a production/mod'd turd engine, w123? 30+ years later? no way! don't forget about the same time they were playinging with the rotary engine in the same chassis, sold off to mazda!
(11-30-2013, 12:48 PM)MFSuper90 I find it hard to believe they slapped a intercooler on it turned the boost up to 30psi different cam and BAM! They have 230hp.
This post was last modified: 12-01-2013, 09:15 PM by Austincarnut.
Austincarnut
12-01-2013, 09:46 PM #14
Ported head & bigger valves (couple hundred)
Custom cam($400ish?)
Bigger pump ($1200ish)
Bigger turbo (varies)
Volker407
naturally aspirated
157
12-03-2013, 09:23 AM #15
(11-30-2013, 02:50 PM)sassparilla_kid I wonder what trans they used, and where can I get one
Unless you have a C111 chassis in stock the gearbox is useless for you....
I live 20 miles away....
(11-30-2013, 05:29 PM)MFSuper90 And can they please discretely steal the camshaft out of it and send it my way? Big Grin
Big Grin
This picture
was taken outside, in front of the museum at a special presentation day where I didn´t have time to visit the museum. Angry
Normally you don´t get any closer than being 5 meters away from the C111.
(11-30-2013, 02:29 PM)DiseaselWeasel Jesus, this is an article by a journalist, not by a diesel tuning guru ffs, give it a break... Smile
You are right, for example the indicated boost in the article is wrong. For the C111 stage 1 engine the boost is specified at 45psi!
Gruß
Volker
This post was last modified: 12-03-2013, 09:56 AM by Volker407.
Volker407
Big Grin
This picture
Gruß
Volker
12-04-2013, 11:04 AM #16
I thought rods started bending at 30+psi in a 617?
Unless they had custom rods or lowered compression?
12-04-2013, 12:44 PM #17
(12-04-2013, 11:04 AM)MFSuper90 I thought rods started bending at 30+psi in a 617?
If I was building an all-out racecar I would definitely use custom rods
Volker407
naturally aspirated
157
12-04-2013, 02:11 PM #18
The engine had custom rods + custom pistons + lowered compression to 1:19
Gruß
Volker
Volker407
Gruß
Volker
12-04-2013, 05:16 PM #19
Ah I see. So it was very built and very expensice
