2nd Flex disk?
2nd Flex disk?
I wanted to replace the flex disks on my 300d, I was able to find the flex disks no problem, except for there is a 2nd flex disk bewteen the front flex disk and the drive shaft. I cant find any part number or part listing for it. That rubber is cracked there too and i want to replace it while im there.
Any one know where to find one?
The appear to have stopped making those several years back, like in the 1990's... If you can find a new one, buy it. Otherwise, what Druk said^^.
It's a harmonic vibration damper. It you identify a problem with it, you can easily remove it from the driveshaft. It's a press fit and can be hammered off without damage to the shaft.
