STD Other FS / WTB / Buying guides FOR SALE: "M" Pump and Steel Lines and Lift Pump
01-04-2014, 07:21 PM #1
OM617.9XX engine application - W123 Chassis
This is a "M" pump which is needed for mod'ing, upgrading, performance.
The pump has NOT been mod'd yet. This also includes the steel lines which are particular to the "M" Pump. I am not parting out the steel lines or the lift pump from the IP. Generally, you need a "core" / swap to send off for mod'ing. That is how I got mine mod'd out, that is, I had to send a core out.
These are tough to come by. I have only found them overseas OR on grey market cars.
$250.00 for the entire deal: 1). the IP and 2). steel lines&brackets and 3). lift pump PLUS whatever the costs of shipping. CONUS Shipping only. Shipping weight should be around 30 pounds. The upgraded lift pump (black pump) generally run $40; the steel lines are tougher to come by and they run in the ball park of $50-$75; and that leaves around $160 for the "M" Pump, so these are reasonably priced to sell. PayPal Only.
PM if interested.
PM if interested.
300SD_KY
super turbo diesel
121
01-29-2014, 08:46 PM #2
Will work with my '79 300SD? I'll buy if still available. PayPal good?
This post was last modified: 01-29-2014, 08:48 PM by 300SD_KY.
300SD_KY
01-29-2014, 10:26 PM #3
My bad. This sold a while ago.
Thanks !
Thanks !
