STD Tuning Engine Holset 3ld
Holset 3ld
Holset 3ld
Booster
01-09-2014, 01:00 PM #1
After a long time deciding if I should use my Detroit supercharger on a 605 I have decided against it! Was going to be far too much work and no idea if it would be good.
I have sold the supercharger and came across a re built 3ld holset? I think it has a 12cm housing!
Any use to me on a 605? Can't find much on the web of people using them? I know they are fairly old now!
Any help would be great!
Booster
Booster
01-10-2014, 11:00 AM #2
Anyone??
Booster
Anyone??
erling66
SuperDieselVan
294
01-10-2014, 12:33 PM #3
(01-10-2014, 11:00 AM)Booster Anyone??
If you give some more info, you will probably get some help.
Comp wheel in out? turbine out in ? photos?
HuhCoolTongue
erling66
HuhCoolTongue
Booster
01-10-2014, 01:34 PM #4
(01-10-2014, 12:33 PM)erling66
Thanks, not much info I can give you as I don't have the turbo.
Serial number and assy number don't come up with much. Will get some pictures to show.
All I want to know is about the 3ld platform/ frame. If there are good or bad ones?
It has a twin scroll 12cm housing, looks similar to the hx35 in size.
No wastegate. Cold side looks like fairly small.
If anyone has seen or used them that would be good if not don't worry!
Booster
