STD Tuning Engine Holset Super HX30
Holset Super HX30
Holset Super HX30
GLTHFJ60
01-09-2014, 02:29 PM #1
Hey everyone,
New to this forum, but not new to diesels. I've got a Cummins 4BT (3.9L turbodiesel) in an old Toyota Land Cruiser.
The HX30w with the 6cm2 turbine housing is regarded as one of, if not the best turbo to run as a single on this motor, however it lacks on the top end. The stock HX30 has a 40mm inducer.
Via this thread on the forum I frequent, 4BTSwaps, it's rumored that there is such a thing as a "Super" HX30 from Holset, with a 46mm inducer, that's supposed to flow more air. I'm in search of more info.
http://www.4btswaps.com/forum/showthread...-4BT/page5
Does anyone know where I can get my hands on this turbo? If not, does anyone know where I can get the compressor wheel and housing from a Super HX30 to fit to a regular HX30w?
Thanks in advance!
GLTHFJ60
Hey everyone,
Thanks in advance!
Mark_M
01-09-2014, 07:36 PM #2
Doesn't answer your question but might get you closer http://www.superturbodiesel.com/std/Thre...M605-Build
Mark_M
Alcaid
01-10-2014, 01:29 AM #3
I'm the "Norwegian fellow" than can get them Wink They have the exact same hot side as the normal HX30W 65/52mm 6cm turbine.
The compressor wheel exducer is bigger so not a plug and play wheel and housing upgrade. I haven't found the parts separately yet either unfortunately
Alcaid
GLTHFJ60
01-10-2014, 08:29 AM #4
(01-09-2014, 07:36 PM)Mark_M Doesn't answer your question but might get you closer http://www.superturbodiesel.com/std/Thre...M605-Build
Yup, that's the thread I found on this forum. I should have put the link above for reference. Thanks!
(01-10-2014, 01:29 AM)Alcaid I'm the "Norwegian fellow" than can get them Wink They have the exact same hot side as the normal HX30W 65/52mm 6cm turbine.
Damn. Well at least we can get the whole turbo! I'll respond to your email shortly.
Thanks!
GLTHFJ60
Thanks!
atypicalguy
02-03-2015, 10:18 PM #5
How is the spool factor on the Super? Im guessind he211/221w is better?
atypicalguy
Alcaid
02-04-2015, 02:42 AM #6
HE211/HE200 with 5cm housings spool faster than HX30W
HE221 with 7cm housing will be very close to the HX30 turbos. Less inertia to spool up but lower compressor efficiency, turbine choke flows are pretty close
HX30W and HX30W share the same turbine and housing so they will spool very similarly
Alcaid
atypicalguy
02-05-2015, 08:54 PM #7
Going for a bolt on 211 5cm in place of the KKK, no intercooler. Will need extender pipe to hook turbo outlet to standard exhaust; Can I order a straight turbo exhaust outlet flange plate from Cummins direct somehow? Anyone have a part number? Thanks.
I'll do the hx30 super later when I do the pump. For now the 211 seems like a great replacement.
atypicalguy
MTUPower
288
02-06-2015, 10:25 AM #8
Which of these is best for a 617-95X with a Myna pump for a daily driver? I'd like to keep the smoke as little as possible.
MTUPower
Alcaid
02-07-2015, 01:25 AM #9
(02-06-2015, 10:25 AM)MTUPower Which of these is best for a 617-95X with a Myna pump for a daily driver? I'd like to keep the smoke as little as possible.
I would say HX30W-6cm with 44mm inducer. With the longer rev range on these no need for the Super compressor wheel as turbine will be the limit anyway
Alcaid
MTUPower
288
08-13-2018, 11:23 AM #10
(02-07-2015, 01:25 AM)Alcaid
Exducer... 52?  I need one now!
This post was last modified: 08-13-2018, 11:24 AM by MTUPower.
MTUPower
MTUPower
288
02-06-2019, 10:19 PM #11
So I'm in the middle of installing my HX30W super and would like to change the exhaust from the immediate down turn 90 degree 2.5 inch to a straight pipe- no downturn 90. I can't use a downturn for routing.  Plus I need a flexpipe.  Please tell me where I can find that?  I've looked everywhere with no luck.
This post was last modified: 02-06-2019, 10:21 PM by MTUPower.
MTUPower
