STD Tuning Engine Turbo cam?? N/A cam??
pmj4147
T04R + TD06
42
01-31-2014, 12:38 AM #1
I heard
"N/A cam has more lift than Turbo cam"
but i could find the information just for 605/606
My question is a.............. It's same with 602/603??
More lift than Turbo cam???
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
I heard
01-31-2014, 01:18 PM #2
I would expect n/a cams to have longer intake duration but I could be mistaken, as I'm not an engineer Wink
01-31-2014, 01:55 PM #3
hello fine people ,
i´m about to check that, cause i have to rebuild a head from a 2 damaged one is N/A the other is T , so i let u know that , but u may start thinking that valve lift is the same , timing no , will be diff , timing in N/A engines must consider some valve overlap to deal with cylinder filling and dinamics of the exaust. on the other way turbo versions want to empty the cylinder as fast as possible to fill it under boost. so u may expect diff timing instead of diff valve lift.
i´ll post my fidings later
regards
FD
hello fine people ,
regards
FD
02-04-2014, 01:27 PM #4
NA exhaust cam on the 605 606. No clue on the 603.
mantahead
02-04-2014, 05:39 PM #5
yea, om606 n/a intake cam had about 1.4mm more lift than the turbo intake cam, exhaust cams where the same.
some info here, http://www.superturbodiesel.com/std/Thre...ght=na+cam
sorry, no info on om603.
This post was last modified: 02-04-2014, 05:40 PM by mantahead.
mantahead
02-04-2014, 06:45 PM #6
(02-04-2014, 05:39 PM)mantahead yea, om606 n/a intake cam had about 1.4mm more lift than the turbo intake cam, exhaust cams where the same.
Thanks for correcting me! I have a 603 turbo cam on my wall of shame I can measure. We never got the 603 NA here, anyone have one on hand?
hansendk
02-04-2014, 08:36 PM #7
I just looked in the KS catalog
602.912 - 602.962 and SsangYong 662.940 use the same cam 602 050 08 01
but 602.980 has a differnt number 602 050 13 01 but the are no info whats is different
hansendk
Eric78
02-05-2014, 12:23 AM #8
Is it the same with the 605?
Eric78
02-05-2014, 03:53 AM #9
question , i can not understand, is your idea fitting a N/A cam in a turbo engine? just because has more lift?
regards
FD
regards
FD
F.R.A.S
02-05-2014, 04:10 AM #10
The BMW guys (petrol/e85) usually drives with a modified intake cam on the exhaust side. Is there a difference there to on the om605/606 engines. So two N/A intake cams on a OM-engine might be awesome. If it's doable that is.
F.R.A.S
02-05-2014, 11:23 AM #11
So ya, my comment about exhaust was based on BSR's new videos for their budget std. He said NA for the exhaust, makes sense that it would be an NA intake. Is the profile the same? Never seen cams on the 605/6.
mantahead
02-05-2014, 03:55 PM #12
ah rite, i was wondering about why the guy on the BSR video said they where using n/a exhaust cam with 1mm more lift.
he must have meant inlet cam.
as Erling pointed out in that other thread about cams, you can't run inlet cam on exhaust side because they run in opposite directions, off the gear, valves will be opening in wrong order.
This post was last modified: 02-05-2014, 04:08 PM by mantahead.
mantahead
