STD Tuning Drivetrain Solid flywheels for the OM60x
simonm16p6
01-31-2014, 06:14 PM #1
I recently picked up a solid flywheel from what I'm told was a W123 230E.
[Image: 100_6178_zpsedbbd92b.jpg]
It's now bolted on the back of my OM605, and I'm in the process of making another gearbox adapter using a Ssangyong Musso T5 bellhousing which I just acquired onto a Rover R380 gearbox.
[Image: 100_6200_zps606d497f.jpg]
I'm just wondering how many different variants of solid flywheel there are that will bolt to the OM60x series of engines, if any and what the differences are? Also I haven't had a chance to measure but how much further back does the friction plate sit on a dual mass compared to a solid flywheel? I've taken the dual mass off my OM605 and put it on an OM606 which is now fitted to my Land Rover, and would like to convert that to a solid flywheel too in the future.
1971 Rover P6 2000 project OM605 compound charged conversion
1975 Land Rover series 3 OM606 project
simonm16p6
aaa
02-01-2014, 08:03 AM #2
There are many, pretty much all the om60x m10x m111 used similar stuff. You'll see differences in pressure plate/friction disc diameter, and different timing mechanisms on the back.
aaa
simonm16p6
02-01-2014, 10:49 AM #3
Ah OK, wasn't sure how many variants there would be, searching through Ebay I've found 215mm and 228mm clutches, and ignoring ignition timing marks would that be the fundamental difference I would encounter if I found another similar solid flywheel?
simonm16p6
