STD Tuning Engine w201 2.9ltr om 602 N/A from T1 310d.
skippy190d
02-03-2014, 04:40 PM #1
Hi all.
Has any one put a 2.9ltr om602 N/A from a T1 310d(pre sprinter)engine into a w201 chassis.Im thinking of taking this on as a project i have sorced the 310d engine and my car is a 1992 w201 190d.
i think the N/A 2.9 ltr 602 puts out 98hp are these engines tuneable at all?
i would love to go with an early sprinter 2.9 turbo but am finding it hard to find one.
any thought or advice much appriciated
regards
Alan
PS,my 190 is the 2ltr d
This post was last modified: 02-03-2014, 04:41 PM by skippy190d.
skippy190d
Hi all.
regards
Alan
F.R.A.S
02-04-2014, 02:24 AM #2
Sounds awesome, go for it. Just a small tune would be super nice, like 6mm elements and a hx35#12 turbo. Will be a lot of fun and durable!
F.R.A.S
skippy190d
02-04-2014, 04:57 AM #3
Thanks for the reply.
The engine i got is the om602 ,5cyl non turbo 2.9ltr from a T1 310d.
I was wondering if any one has used one of these engines,as standard they put out 98hp,is it possible to get maybe 130hp without a turbo by ajusting the pump alone?
skippy190d
cho
02-04-2014, 05:09 AM #4
one way or another...you will need AIR Smile
cho
hansendk
02-04-2014, 06:51 AM #5
SsangYong is using the same engine and with turbo/intercooler it has 120 HP so there is no way you can get 130 HP on a N/A engine without massive black smoke
but why not find a SsangYong engine there are plenty in the UK its a OM662LA engine 2,9 L
hansendk
skippy190d
02-04-2014, 07:47 AM #6
Thank you for the replies.
@Cho,air is the key alright,i was thinking maybe a k&n filter and uping the pump slightly,any idea what hp gain is possible by doing this or am i flogging a dead horse.?
@hansendk,yes hansen i have seen that people have used the Ssangong engine with mixed results,usually down to infirior build quality on these engines.Will this engine drop straight into a w201 chassis?what is your opinion on the reliability of this engine?
skippy190d
hansendk
02-04-2014, 09:57 AM #7
who told you about quality don't know what they are talking about, its the same as MB all the parts are the same they get the pistons from the same place as Mercedes if you have 2 engines side by side you cant tell the different you have to look at the oil sump because the sump is in the rear.
but what do I know I just spend the last almost 30 years working with engine remanufacturing.
Mercedes used to be a lot better than the rest but now all are stepping up and I have seen a ton off broken heads and pistons on commenrail engines before 200.000 KM, and some get very angry and say it a Mercedes it should run much more.
hansendk
mario
06-22-2014, 01:40 PM #8
I have a friend here who might have an om605 non turbo with the ecu and all but it can have the immobiliser removed if this is any help.
mario
