STD Tuning Engine Information about the valve springs om601/2/3
Flakis
02-19-2014, 06:12 AM #1
Someone who knows a little about the dimensions of the valve springs for Om601/2/3? : D
Me thought response to these:
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
Would have been wonderful if anyone knows Smile
This post was last modified: 02-19-2014, 06:14 AM by Flakis.
Flakis
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
Duncansport
02-19-2014, 09:26 AM #2
(02-19-2014, 06:12 AM)Flakis Someone who knows a little about the dimensions of the valve springs for Om601/2/3? : D
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
http://www.superturbodiesel.com/std/Thre...ve-springs
Duncansport
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
Flakis
02-19-2014, 10:00 AM #3
(02-19-2014, 09:26 AM)Duncansport
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
Thanks Big Grin
Flakis
Outer diameter:
Inside diameter:
Wire diameter:
Length unloaded:
Length loaded:
Spring Value:
Thanks Big Grin
