STD Tuning Drivetrain w202 180 manual in W124 om603
superturbo
02-28-2014, 06:47 AM #1
Hi
I have a Mercedes Bens c-class 180. it has 1,8 gasolin engine and an a manual gearbox (same one that is in the C280 straight-6) and im wondering if i can put the manual gearbox in an e-class 300tdt? i dont have one at the moment but im thinking og buying one Wink
sorry for my bad english, i hope you understand.
superturbo
Hi
aaa
02-28-2014, 09:28 AM #2
Should bolt up to the engine fine. The rear mount will be different, and it's probably dualmass.
aaa
superturbo
02-28-2014, 10:40 AM #3
so i need a new flywheel, and to get it re welded to fit? can i use a flywheel from a 300td (non turbo) manual?
superturbo
tjts1
02-28-2014, 12:23 PM #4
You can re use your existing C180 flywheel. I put a 1992 190e 5 spd behind an OM603. Transmission should be very similar to your C180. I believe the W202 manual pedal box also swaps over into the W124.
http://www.superturbodiesel.com/std/Thre...speed-swap
This post was last modified: 02-28-2014, 12:24 PM by tjts1.
[Image: 208104.png]
tjts1
[Image: 208104.png]
Dieselsec
03-01-2014, 05:35 AM #5
(02-28-2014, 12:23 PM)tjts1 You can resuse your existing C180 flywheel. I put a 1992 190e 5 spd behind an OM603. Transmission should be very similar to your C180. I believe the W202 manual pedal box also swaps over into the W124.
Hi sorry to hijack thread. I'm considering a 5 speed manual swap also onto my om606. If I buy a 190d 2.5 diesel with 5 speed manual, will the flywheel fit and be balanced on my om606?
The auto started flaring after driving it for about 30 mins with the ppdiesel pump so I think a manual would hold up bit better.
Dieselsec
capflya
Dreaming of a VNT
309
03-05-2014, 02:32 AM #6
it will fit but clutch may not hold up. You need a flywheel and clutch setup from a 190e 16v or a 300E manual type setup (9" and 9.5" respectively).
Should even get a performance clutch/pressure plate if you have a built IP.
capflya
Dieselsec
03-05-2014, 03:46 PM #7
(03-05-2014, 02:32 AM)capflya it will fit but clutch may not hold up. You need a flywheel and clutch setup from a 190e 16v or a 300E manual type setup (9" and 9.5" respectively).
Thanks for the info
Dieselsec
Thanks for the info
