STD Maintenance General Need photo of how vacuum hoses run, top of 1983 300D (SOLVED)
JustPassinThru
W123 and W124
491
03-07-2014, 09:37 PM #1
Specifically, that sensor+switch just inboard of the EGR, has two vacuum tubes running out of it; at least one goes to the black rubber 5-port fitting attached to all the throttle linkage atop the valve cover, but...which hose plugs into which fitting on that 5-port? ...and the other hose from the sensor+switch goes to...? ...the EGR nipple? Can someone please snap me a pic or point me to a diagrammatic URL. Thanks.
OK got it, thanks.
This post was last modified: 03-07-2014, 10:10 PM by JustPassinThru.
JustPassinThru
OK got it, thanks.
