STD Other FS / WTB / Buying guides WANT TO BUY: AXLE SHIMS
03-17-2014, 01:11 PM #1
I know once I buy these, I will find my baggie of axle shims which is somewhere floating around in my garge.
W123 application ... not sure the inner or outer diameter of other cars will work.
I currently found in my garage's "junk box" one which is .90 and another which is .95. Looking for some bigger ones and maybe a few which are smaller.
Thanks in advance.
Thanks in advance.
Druk
03-17-2014, 05:47 PM #2
107, 124 and 126 shims are all the same fitting so likely 123 will be too. They're still available from Merc for not-a-lot. Figure out first what you need then order them up. Manual recommends replacing circlips at same time. Why not??...they're as cheap as chips.
This post was last modified: 03-17-2014, 05:48 PM by Druk.
Druk
