STD Tuning Engine relocating battery to trunk tomorrow
300SD_KY
super turbo diesel
121
04-07-2014, 01:32 PM #1
looking forward to extra room in the engine compartment ... maybe one day, for a cold air intake fed by some side vents ... some headers ;-)
This post was last modified: 04-09-2014, 05:00 AM by 300SD_KY.
300SD_KY
snowbrd84
04-08-2014, 08:21 AM #2
I nice way to do it is to buy a marine battery box, cost less than 20 bucks and will ensure the terminals are not exposed. Just make sure you mount it in a location that you will be able to easily hook up jumper cables. Just imagine a trunk full of luggage and a dead battery, a quick jump turns into unloading everything...
snowbrd84
Jetmugg
04-08-2014, 09:01 AM #3
From a safety standpoint, using a sealed battery box with external venting is the preferred option. Obviously, you are free to do what you see fit, but thought I would offer this up.
Steve
Jetmugg
Steve
300SD_KY
super turbo diesel
121
04-08-2014, 09:28 AM #4
(04-08-2014, 09:01 AM)Jetmugg From a safety standpoint, using a sealed battery box with external venting is the preferred option. Obviously, you are free to do what you see fit, but thought I would offer this up.
Steve
Steve, good thinking ... any thoughts/experience on ...
Moroso NHRA legal: http://www.rpmoutlet.com/musv6batt.htm
Noco Marine: http://www.boatdepot.com/p-4090/noco-gro...Mgod5nUALw
other?
300SD_KY
Steve
other?
mach4
R107 Diesel
35
04-08-2014, 10:33 AM #5
My 380SL (617 powered) has the battery in the trunk. You might be able to find a complete setup in the junkyard - long cable, battery box, block, etc. It would be sized for the MB battery too.
mach4
Jetmugg
04-08-2014, 11:01 AM #6
I used to be "into" boats fairly deeply. Any time something says "Marine" on it, the price is doubled.
Drag racing stuff is relatively cheap compared to marines stuff. I think that Moroso box would keep you safe.
Steve.
Jetmugg
Steve.
300SD_KY
super turbo diesel
121
04-08-2014, 08:21 PM #7
the job is done ... works great, with 1/0 gauge cable, 300 amp fuse box, and marine battery box secure in the rear, which allows me to keep a spare ... for now, keeping the original battery tray ... but that will go before too long: http://bit.ly/1lOSTqV
This post was last modified: 04-09-2014, 08:45 PM by 300SD_KY.
300SD_KY
ShaggyDiesel
Let the Wookie win
23
04-10-2014, 10:10 PM #8
just throwing this out there but how about going with a lithium-ion battery. the cost is higher, but smaller size and lower weight.
All gave some, Some gave it all ~ 9/11 Never Forget
People shouldn't fear their Government, The Government should fear its people.
ShaggyDiesel
300SD_KY
super turbo diesel
121
04-10-2014, 10:19 PM #9
when i win the lottery ;-) lithium-ion batteries EXPENSIVE ... $2k up
my butt-dyno says the car handles better with the 70-pounds of batter in the trunk.
fit-and-finish wise (as well as long-term use), i am glad that the battery cable goes from the trunk, under the rear seat, under the carpeting to the engine compartment ... one alternative was to run the cabling underneath the car, with zip ties = no thank you.
300SD_KY
snowbrd84
04-11-2014, 08:30 AM #10
(04-10-2014, 10:19 PM)300SD_KY when i win the lottery ;-) lithium-ion batteries EXPENSIVE ... $2k up
You can run it under the car too, buy a long piece of pvc pipe, 1/2" or 3/4", whichever is needed to fit the cables. With a heat gun, you can bend the pvc pipe very easily to fit the contour of the undercarriage from front to back in one singe piece. Paint the pvc black to not stand out. Get about 20 feet of twine and your vacuum, with the vacuum attachment on one end of the pipe, feed the twine in until it is sucked out the other side. VERY securely afix the twine to the + & - cables, put a little grease or lubricant (anything that wont damage the cable insulation) on a rag, run it down the length of the cable, then pull the cables through the pipe.
Might sound like a lot of steps, but its pretty simple really. This is how we used to run electrical wire through conduit that was already inplace under concrete. We could pull cable through over a 100' of 3/4" pvc, so...
This post was last modified: 04-11-2014, 08:31 AM by snowbrd84.
snowbrd84
04-11-2014, 02:33 PM #11
My problem with putting the battery in the trunk is my springs are already extra saggy and my car looks like a dog dragging its ass across the carpet, and then there's the issue of where is the spare tire gonna go after I fill it's space up with batteries
300SD_KY
super turbo diesel
121
04-11-2014, 04:59 PM #12
(04-11-2014, 02:33 PM)sassparilla_kid My problem with putting the battery in the trunk is my springs are already extra saggy and my car looks like a dog dragging its ass across the carpet, and then there's the issue of where is the spare tire gonna go after I fill it's space up with batteries
I've got Bilstein HDs all around and H&R sport springs ... they handle anything without sagging. The install allows the spare tire to stay in the trunk = perfect ... Check it out: http://bit.ly/1lOSTqV
300SD_KY
Tmadia
04-12-2014, 11:09 AM #13
I think it looks really good and it's something I've been planning on doing as well.
'85 300CD
Tmadia
'85 300CD
