STD Maintenance General om603 into 300d w123
anths
04-19-2014, 02:53 AM #1
Hello,
Im trying to find information on what need's to be modified to fit a om603 3ltr 6 into a w123 body to replace the old om617 and transmission
will I be able retain original drive shaft, ect ect
Any help in would greatly be appreciated
I have seen pictures of om606 into w123 but no information on om603 mounts
many thanks anthony
This post was last modified: 04-19-2014, 06:01 PM by anths.
anths
Hello,
many thanks anthony
EmJay
04-19-2014, 05:34 PM #2
What transmission are you wanting, a 722.4 or a 5spd?
EmJay
anths
04-19-2014, 05:59 PM #3
(04-19-2014, 05:34 PM)EmJay What transmission are you wanting, a 722.4 or a 5spd?
Transmission is a 722.358 automatic i was hoping i could use the original drive shaft
cheers anthony
anths
cheers anthony
04-21-2014, 01:36 AM #4
I think ksteen or somebody did this with not too much modification
http://www.superturbodiesel.com/std/Thre...ily-driver
This post was last modified: 04-21-2014, 01:38 AM by sassparilla_kid.
Tito
04-22-2014, 02:13 PM #5
I did it once. You could fit the box to the original automatic driveshaft, but the engine sits very far to the front. Both 603 engine and w123 where already an automatic. You'll need to drill 2 holes in the chassis for the gearbox support. I thought de w124 support fits on 2 bolts and you can easily drill the other holes. You'll also need to move the radiator to the right a few cm's for the steering pump to clear the radiator. The fan will not fit and needs to become electric. I did the motor mounts with spacers on the right side, and a homemade one on the left.
I would recommend shortening the driveshaft and move the engine further back.
And of course you got the standard problems, exhaust, wiring an so on.
This post was last modified: 04-22-2014, 02:14 PM by Tito.
Tito
