STD Tuning Drivetrain om605 flywheel and gearbox options
RickyE
05-07-2014, 10:14 AM #1
Hello, i have a w202 with a om605 and manual 5 speed, its a very slow revving engine and idealy i want something that revs up and down quicker, so i am looking at a single mass flywheel
Have searched around but cant make alot of sense, i know om602 flywheels fit onto the om605 flywheel, but what im not sure about is sensors for the electronic pump on the om605, as i will still be running the same pump for a while until funds say i can do otherwise
Also gearboxes, do the 6 speed boxes from w203's fit onto these engines, not to worried about ratios as i can change diff's to get the ratio i need, problem i have atm is i am running a low ratio diff and its revving quiet high for daily driving, would be nice to have 6th to help keep the rev's down when driving to work, but still have lower ratios for drifting
Cheers
RickyE
Cheers
Stevo-trendy
05-07-2014, 03:26 PM #2
W203 c270cdi six speed box fits & it's believed to be one of the strongest boxes to run for big power so I've read
Stevo-trendy
RickyE
05-07-2014, 04:36 PM #3
cheers stevo, ill have to phone around a few scrap yards here, but if the prices on ebay are anything to go by i dont think ill be getting one of them any time soon, seem to be going for more than my cars costing me
RickyE
hooblah
05-07-2014, 05:29 PM #4
Ricky the best thing would be to compare what the difference is between the flywheels. Do you have a pic of the 605 flywheel?
hooblah
F.R.A.S
05-09-2014, 11:13 AM #5
Most flywheels fit. But slow revving is because you have the stock IP. With a superpump you'll have the throttle response of a motorcycle.
Big Grin
F.R.A.S
Big Grin
RickyE
02-20-2016, 12:56 PM #6
going to bump an old thread instead of starting a new one here
had the car out for the first time today, clutch is completely gone, so looking at a flywheel and clutch
before i go buying a flywheel i wanted to make sure, does a sprinter solid mass flywheel fit? and i asume it has to be a sprinter with a om605 for the flywheel to work if it does fit
in abit of a panic for one as its out again in 2 weeks time
RickyE
F.R.A.S
02-22-2016, 04:25 AM #7
There are no sprinters with 605 Smile But any straight engine FW will fit. If you want it to hold some power you are way off though.
F.R.A.S
Tobulus
02-26-2016, 07:35 AM #8
(05-09-2014, 11:13 AM)F.R.A.S Most flywheels fit. But slow revving is because you have the stock IP. With a superpump you'll have the throttle response of a motorcycle.
Big Grin
With a remap, the engine will also rev a lot faster. A lower exhaust pressure will also make a really big difference, so the stock turbo is the bottleneck here.
Tobulus
Big Grin
EvoPeter
03-10-2016, 11:59 PM #9
I have the Sprinter Solid dualmass and a 6-speed gearbox from w203 in my 190. I had to machine 10mm in the front of it for clearance and 15mm in the rear to fitt the Sachs 707 on it. Dont bother with the 765.
EvoPeter
EvoPeter
03-11-2016, 12:03 AM #10
Link to the flywheel that some ppl here uses.
http://www.ebay.com/itm/261585027068?_tr...EBIDX%3AIT
Fitts only dualmass gearboxes tho.
This post was last modified: 03-11-2016, 12:04 AM by EvoPeter.
EvoPeter
mklogz
06-16-2017, 08:42 AM #11
(03-10-2016, 11:59 PM)EvoPeter I have the Sprinter Solid dualmass and a 6-speed gearbox from w203 in my 190. I had to machine 10mm in the front of it for clearance and 15mm in the rear to fitt the Sachs 707 on it. Dont bother with the 765.
Hi what is this Sachs 707 you speak of ? I know the 765 is the BMW m5 clutch thanks
mklogz
