STD Tuning Engine W140 500sec om606
W140 500sec om606
W140 500sec om606
dekeinsan
06-22-2014, 09:11 AM #1
Hi,
I have a 1993 w140 coupe. Unfortunately, the engine because no Water was left.
Since I'm very happy with my G wagon superturbo, I think it is a good idea to replace the engine with om606.
I'd like to get as much as the original engine, not less than 300hp, suitable for daily driving.
I believe the pump issue is solved by dieselmeken. I will have a custom manifold made.
Which turbo will provide the hp without much lag is the question.
Ball bearing turbos from garrett or hx35 will do fine?
Thanks in advance,
dekeinsan
Hi,
Thanks in advance,
mario
06-22-2014, 01:24 PM #2
Good luck with the project as any pics of the car. Will you need to swap the power steering pump over.
mario
maxypriest
06-25-2014, 06:47 AM #3
http://www.dieselpumpuk.com/home.html
You can get help from this chap, fairly sure he can supply the lot.
maxypriest
dekeinsan
06-26-2014, 04:52 PM #4
(06-22-2014, 01:24 PM)mario Good luck with the project as any pics of the car. Will you need to swap the power steering pump over.
Thanks, no pictures; it is parked in the very dark side of the garage. Will post picks after pulling it out.
(06-25-2014, 06:47 AM)maxypriest http://www.dieselpumpuk.com/home.html
Thank you, I sure amg going to contact them.
This post was last modified: 06-26-2014, 04:53 PM by dekeinsan.
dekeinsan
