STD Tuning Brakes W211 calipers onto w202
08-12-2014, 02:55 PM #1
Any thoughts? I have been offered a pair of them, aluminium 4-pots for £80 shipped!
They'd likely fit a w210, and I know (suspect/hope to god) w210 calipers fit a w202..
Doe sanyone have any compatibility experience?
Thanks, I'll post pictures of the conversion and doccument the swap assuming I do it, likely fabricated fluid lines nessecary.
Thanks again, H!
Thanks again, H!
08-13-2014, 08:02 AM #2
They're a pair of these btw!..
[Image: MercedesE320CDISportW211brakecaliperNSF.jpg]
tjts1
08-13-2014, 09:46 AM #3
W210 and W202 calipers are interchangeable. The US market W210 E300 diesel non turbo came with W202 calipers and rotors from the factory. No clue about W211 but the brakes are mounted on opposite sides of the axle. W210 is ahead of the axle, W211 is behind. At the very least you'll have to swap the left and right to keep the bleed screw at the top.
[Image: 208104.png]
tjts1
[Image: 208104.png]
08-14-2014, 06:52 AM #4
Aha, great, that is the case with the W202 C32AMG caliper swap to onto a ctock W202 so that is fine, thanks for the info. I will update this thread when they come through the post.
