sprinter engine
sprinter engine
Can a 312 or other sprinter engine be made to run without an ecu to control it ? ie a different pump or modified original pump ?
Anyone already done it
Thanks Nige
Hello 2.9td with the bosch pump mark 1 sprinter with gearstick through floor ? Or later cdi engine 2.2 with gearstick on dash ?
(08-23-2014, 07:57 AM)Petar If it's a 312D then it's the old 2.9td with direct injection.
Yes it can be made mechanical with a mechanical VE pump,have seen it a couple of times.
AFAIK there is no bolt on mechanical pump available for that engine but can be built.Ask dieselmeken.
& om662la from ssyanong musso idi mechanical injector pump , 2.9 turbo 5 cylinder
You can supposedly run an mechanical pump with the 2.9 from the sprinter.. problem is that 2.9 om602 is a direct injection. From what i'm hearing it is definitely possible but you will run into problems. I have been looking around the interwebs for a while for some research and only came up with results of ssangyong musso swaps. Not too familiar with the 2.9
