STD Tuning Engine 617 into 190D
617 into 190D
617 into 190D
IsaacDW
Turbo-charged
26
08-05-2009, 05:50 PM #1
I have found a potentially good deal on craigslist for a 1986 190D. From what I can find, the OM602 that is in the 190D is naturally aspirated.
Since I have a "spare" 617 turbo, would an engine swap into the 201 chassis be feasible. The 190D has the five speed manual, which would be my main reason for the swap.
I have absolutely NO idea if anything would fit. Has anyone done or thought about doing this swap before? I just want to explore the possibility. What do you think?
IsaacDW
08-05-2009, 07:47 PM #2
Its possible but you would need to make adapters for the engine mounts and that 5-speed will not attach to the engine.
There is also the legality issue of putting an older engine into a newer body, some states might not let you register the car.
IsaacDW
Turbo-charged
26
08-05-2009, 08:34 PM #3
That sounds like it would be far more hassle than it worth. Thanks!
IsaacDW
totaldisaster
lightly modded OM606
211
08-05-2009, 09:41 PM #4
Personally, you are downgrading that car by dropping the 617 in there.
Even if you shoe it in there, your weight distribution is gunna suck. I wouldn't be surprised if the handling becomes sloppy with that anchor up in the front too.
...just thoughts..
totaldisaster
...just thoughts..
08-05-2009, 10:14 PM #5
You can get an om606 om603 should bolt up in there the 6 cly diesel and work with that transmission! but they are hard to find for a reasonable price
2.5-10
Nothing Clever
67
08-06-2009, 09:41 AM #6
I have contemplated a 616-4speed swap in my spare 190 chassis, it looks pretty easy if you have the transmission from the 617, but yes It will not bolt up to the 5-speed because of a certain starter bung.
1976 W115 medium red/tan 240D (undergoing M117 heart transplant)
1989 BMW E30 327iC SETA 5MT
1987 white/black 190D Turbo Diesel - Recaro 16V seats, Monoblocks, 11PSI.
2009 white/black C63 ///AMG
1987 BMW E30 325E M50B25NV 24V swap 5MT. 5 lug.
1999 white/grey ML430
1991 BMW E30 318i 5MT (Beater)
1990 BMW E34 525i 5MT
1997 red/black/black SL600
2.5-10
