WTB: OM60* accessories
Want to get the OM606 out of a smashed '98 E300 into an 87 300TE that threw a rod.
as I was torching and pulling apart the front end noticed there are some smashed bits on the front.
Water Pump need the whole assembly and fan
alternator & bracket
Belt Tensioner pulley
hopefully that's all for now. I've called every yard within 100 miles and can't seem to find the water pump assembly online.
will do paypal or willing to trade away any OM617 bits you might need.
Thanks to Winmutt for the 603 injection pump!
(08-29-2014, 11:53 AM)llopness Want to get the OM606 out of a smashed '98 E300 into an 87 300TE that threw a rod.
Does anyone know if the OM602 will have all the same stuff? also need the timing chain cover(could weld it too.)
have a line on a 190d for $500, 3 hours away, that someone let a set of students change their glow plugs and someone messed with the throttle so it fired up WOT and they stopped it with a fire extinguisher.
Or a $300 602 equally distant but already out of the car.
