STD Tuning Engine kkk14(om606) vs kkk24(om603) what turbo is better?
PedroFerreira
12-10-2014, 02:22 PM #1
what turbo is better,kkk24(om603) or kkk14(om606)?
PedroFerreira
PedroFerreira
12-10-2014, 03:58 PM #2
someone can help me please?
PedroFerreira
Duncansport
12-11-2014, 08:09 AM #3
Define better....
They are both old tech. The 14 uses a special flange and the 24 uses a T3 flange. not really swapable between the two. The 14 is really small..
Duncansport
Define better....
PedroFerreira
12-11-2014, 01:45 PM #4
the turbo of the 606 is smaler than the 603?
PedroFerreira
12-11-2014, 09:07 PM #5
They did put the 14 on the 602.
Max
Turbinaaa
87
12-13-2014, 06:14 AM #6
(12-11-2014, 01:45 PM)PedroFerreira the turbo of the 606 is smaler than the 603?
Yes, Exhaust Side from the 606 is a bit smaller.
Compressor ist nearly the same Size.
______________________________________________________________
93´ W124 300TDT -> OM606.962 / RS 203 Dieselmeken 7,5mm 210cc / KKK K14 / Stock Transmission / 2,65 ASD
89´ 190D 2.5 Turbo -> OM605.960 / Dieselmeken 7,5mm 180cc / Holset HX30 Super / 716. 654 6-Speed / 2,87 Rear Axle
Max
uli124125
12-13-2014, 08:31 AM #7
hi
max do you speak abaout the Turbo of the 603 35A or about the Turbo of the 3 litre engine?
i think the kkk24 is on both side bigger
i drive it on a 602 2.5 litre engine
for daily use with bigger german elements, almost dustfree and ca 190hp it is perfect i drive the 124 250TDT with ca 8 litre as daily driver in summer
uli124125
hi
w201 602 std
05-23-2015, 01:56 PM #8
Hi
I have kkk14 from e300 on my 602 with 7mm elements.
https://www.youtube.com/watch?v=r8w7bUntIQo
w201 602 std
Hi
05-23-2015, 02:34 PM #9
boas camarada pedro,
nenhum deles é bom para tuning!!! se for para por num motor 2.2, o do 606 é bom!!!
they are both good for the bin , or for a 2.2 engine lol
