STD Tuning Engine TD05-14G with TD06-25G... good for compound use??
pmj4147
T04R + TD06
42
12-11-2014, 10:26 AM #1
I'm running OM662 with 7.5mm IP, TD06-25G(84mm)
max boost 2.4bar
but the spool speed is just a crap!!!!!!!!
so i decided to add a little fella in the game!
Same TD series but different size
small is for max.280hp
big one is for max.700hp
each exhaust housing size - 8cm, 10cm
Will be working well??
This post was last modified: 12-11-2014, 10:28 AM by pmj4147.
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
max boost 2.4bar
