STD Tuning Drivetrain om605 best gearbox and clutch
Y444TES
01-13-2015, 02:27 PM #1
Hi all
I'm collecting all my bits together ready to build my om605 w201 and I've done loads of reaserch but it boggles the mind after a bit with all the different set ups people have but I've got a 716.654 6 speed box and a sprinter and conversion kit would this setup work with my om605. As well I have a getrag cosworth box but no clutch setup and no idea what to use and any help would be greatly appreciated thanks
Oh and my om605 has a 7mm pump and hol set hx30.
Y444TES
Hi all
F.R.A.S
01-13-2015, 03:23 PM #2
BMW ZF gs6-37dz is a good option with a single mass flywheel, 765 PP and a organic clutch. Will never break and you have a 6spd for top speed and economics Smile
(01-13-2015, 02:27 PM)Y444TES Hi all
F.R.A.S
Y444TES
01-14-2015, 03:08 AM #3
Hi F.R.A.S i was looking in to this but i was thinking i wanted a setup i could just bolt on for now and look in to having a better setup later with the bmw gearbox as you have to cut and weld a new bellhousing on thanks for the help.
Y444TES
raidaru
01-14-2015, 03:54 AM #4
FRAS , I thought GS6-53DZ is better than GS6-37DZ !? is it not?
raidaru
CRD4x4
CompoundSuperTurboDiesel4x4!
399
01-14-2015, 09:37 AM #5
Y444TES,
It sounds like you're combo of OM605 + 716.654 with Sprinter solid flywheel & clutch is an excellent start! Ancillaries like throw out bearing, linkages & such may have to be made for it but that should be easy for you to do or hire out.
Your W201 was a manual to begin with, right?
Does your Getrag Cosworth gearbox have a removable bellhousing?
I *think* they're the same/similar to the BMW Getrag 265/5 & 265/6 (dogleg & overdrive, respectively). Wouldn't yours bolt up to a 617?
I have a 265/6 and I'm looking for cheap clutch options so I test fitted a Ford 10-spline clutch disc & amazingly it fit the input shaft splines perfectly.
That could open up a world of dirt cheap performance clutches and then maybe a OM605 + Getrag Cosworth 5-speed would make more sense.
Anyone ever put a Ford clutch on a BMW before?!
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Y444TES,
F.R.A.S
01-14-2015, 11:25 AM #6
Absolutley, the 53dz is a super strong gearbox but the 37dz is half the money and is still twice as strong as the strongest Mercedes gearbox you can find.
(01-14-2015, 03:54 AM)raidaru FRAS , I thought GS6-53DZ is better than GS6-37DZ !? is it not?
F.R.A.S
Turbo
01-14-2015, 12:02 PM #7
And what torque in Nm would you say that is?
BR
(01-14-2015, 11:25 AM)F.R.A.S Absolutley, the 53dz is a super strong gearbox but the 37dz is half the money and is still twice as strong as the strongest Mercedes gearbox you can find.
Turbo
BR
F.R.A.S
01-14-2015, 02:34 PM #8
ANY. The Mercedes gearboxes are just pure shit. The only main thing with them is that they fit. Yea or almost... They only fit if you have a dual mass flywheel. People in Sweden witch you should know are going 1000whp with the old BMW miniature 5spd TDS-gearbox rated to 320Nm. The newer 6spd are tougher than that. And they work on all gears. In a Mercedes you have to do 1st, 2nd, 4th, 5th cause 3rd is made of glass.
/ F
(01-14-2015, 12:02 PM)Turbo And what torque in Nm would you say that is?
BR
F.R.A.S
/ F
BR
Duncansport
01-15-2015, 10:53 AM #9
Hows that Tremic adapter coming along?
Duncansport
F.R.A.S
01-15-2015, 11:29 AM #10
Had a surgery 5-weeks ago and another one on monday (19th) but have made a drawing of the jig we gonna use Smile
Soon I'll post some pictures of the final product.
(01-15-2015, 10:53 AM)Duncansport Hows that Tremic adapter coming along?
F.R.A.S
Duncansport
01-15-2015, 01:33 PM #11
Awesome
Your really putting the fear of god into me about my .430 haha
Duncansport
Awesome
01-15-2015, 02:24 PM #12
(01-14-2015, 09:37 AM)CRD4x4 Does your Getrag Cosworth gearbox have a removable bellhousing?
It's not removable. The Cozzie gearbox is a 275z and BMW is a 265. I have no idea how similar they are.
Stamsaas
01-15-2015, 03:26 PM #13
(01-15-2015, 01:33 PM)Duncansport Awesome
717.430? Yeah, stay away from 3th gear :p
This post was last modified: 01-15-2015, 03:26 PM by Stamsaas.
Stamsaas
Y444TES
01-15-2015, 05:04 PM #14
Thanks for the help lad and them 37DZ boxes are a lot cheap than 53DZ boxes and you have got me thinking now I might just get a bmw box and go down that root
What flywheel would I need for the GS6-37DZ box.
Cheers Sam
Y444TES
Cheers Sam
Turbo
01-15-2015, 05:28 PM #15
Well I asked a about torque since the power transfer is a product of angel velocity and torque, if you have high rpm it not that strange it going to be high HP rating, so you say with 1300Nm of torque and slick it will hold together?
so you are making a tremec adaptor, very interesting, for what version of gear box?
(01-14-2015, 02:34 PM)F.R.A.S ANY. The Mercedes gearboxes are just pure shit. The only main thing with them is that they fit. Yea or almost... They only fit if you have a dual mass flywheel. People in Sweden witch you should know are going 1000whp with the old BMW miniature 5spd TDS-gearbox rated to 320Nm. The newer 6spd are tougher than that. And they work on all gears. In a Mercedes you have to do 1st, 2nd, 4th, 5th cause 3rd is made of glass.
/ F
BR
Turbo
/ F
BR
F.R.A.S
01-15-2015, 05:49 PM #16
We always makes it for a singlemass flywheel and always go Sachs 765 PP. That's easy, cheap and durable. Then you can choose organic clutch, 4-point sinter, 6-point sinter, sprung or not etc.
(01-15-2015, 05:04 PM)Y444TES Thanks for the help lad and them 37DZ boxes are a lot cheap than 53DZ boxes and you have got me thinking now I might just get a bmw box and go down that root
Cheers Sam
The 53dz will have no issue @ 1300Nm and slicks. The 37dz is weaker but as long as you don't build a large tire dragrace car with 4-link and line-lock you'll be fine.
I don't have any Tremec at hand I'm afraid so the only gearbox I know it will fit is the Ford and Chevy Tremec T56. Maybe the T56 Magnum has the same bellhouse bolt pattern, that would be awesome. And I'm not building an adapter I'm building a complete bellhouse with the right distance for the input shaft and so on...
(01-15-2015, 05:28 PM)Turbo Well I asked a about torque since the power transfer is a product of angel velocity and torque, if you have high rpm it not that strange it going to be high HP rating, so you say with 1300Nm of torque and slick it will hold together?
F.R.A.S
Cheers Sam
Turbo
01-16-2015, 10:16 AM #17
what clutch would you recommend for 1200-1300nm of torque
when do you think you will have a bellhause finished for tremec?
(01-15-2015, 05:49 PM)F.R.A.S We always makes it for a singlemass flywheel and always go Sachs 765 PP. That's easy, cheap and durable. Then you can choose organic clutch, 4-point sinter, 6-point sinter, sprung or not etc.
Cheers Sam
Turbo
Cheers Sam
F.R.A.S
01-16-2015, 12:20 PM #18
3-disc Tilton.
Tremec bellhouse will be done in two weeks give or take. Have surgery coming up on monday but I'll try to get it done asap.
(01-16-2015, 10:16 AM)Turbo what clutch would you recommend for 1200-1300nm of torque
F.R.A.S
3-disc Tilton.
Turbo
01-16-2015, 01:48 PM #19
may I ask why you building a bell house for Tremec?
(01-16-2015, 12:20 PM)F.R.A.S 3-disc Tilton.
Turbo
F.R.A.S
01-16-2015, 02:26 PM #20
It's easy. Swedes are a world minority and for one thing we fabricate and sell here we sell 10-12pc to the US and another 5pc to the rest of the world.
In the US the 53dz gearbox is pretty hard to find and the Tremec are in the dozens. The Tremec is a pretty good gearbox with plenty off upgradeable parts available. It also have a removable bellhouse witch makes it perfect for a custom installation.
(01-16-2015, 01:48 PM)Turbo may I ask why you building a bell house for Tremec?
F.R.A.S
Turbo
01-16-2015, 02:51 PM #21
I have thinking many times about a T56 magnum of many reason, and you can buy a cryo hardened that take 1500NM in all gears, but the old t56 like in viper you can not shift fast, and in my case 4 bars of boost does not come back in a blink of an eye, the new t56 magnum shall be much better then the old but how much better?
have you come up with a price on that bell house?
(01-16-2015, 02:26 PM)F.R.A.S It's easy. Swedes are a world minority and for one thing we fabricate and sell here we sell 10-12pc to the US and another 5pc to the rest of the world.
Turbo
F.R.A.S
01-16-2015, 03:50 PM #22
When I looked in to the T56 versions the Viper gearbox was the weakest actually.
The Magnum is supposed to be really tough! I have to make one first to see what it lands on in hours and material. Keep your eyes open and I'll post a picture on the forum as soon as it's done.
(01-16-2015, 02:51 PM)Turbo I have thinking many times about a T56 magnum of many reason, and you can buy a cryo hardened that take 1500NM in all gears, but the old t56 like in viper you can not shift fast, and in my case 4 bars of boost does not come back in a blink of an eye, the new t56 magnum shall be much better then the old but how much better?
F.R.A.S
raidaru
01-16-2015, 04:42 PM #23
brahs, I've been having this thought on my head for some time now, couldn't it be made an adapter plate with the holles for om606 engine and in such a way that the bmw gearbox can be welded directly to the plate without cutting the bellhousing? even if u cut a few places in the bmw bellhousing for puting the screws/strenghtening, but to be a standard adapter plate that u can't go wrong with the welding angles and stuff, I believe it should be possible, and the plate to be as thin as possible but still enough rigid Smile it would be best thing for om606 after the superpump Big Grin tremec&stuff is a dream for most of us, but a f...ing 5 spd from e39 530d is 400euros and full of them! People are dragracing 1000+nm on this boxes!!! Let's put our minds to work and sort this project out! And also the SMF that has to be machined to take the SACHS 765 PP . And everybody will be happy and burnin tyres, not cracking 3rd gears!!!
raidaru
F.R.A.S
01-16-2015, 05:00 PM #24
I don't have the measurements for dual mass flywheels but for single mass this is not possible I'm afraid Sad
The input shaft off the gearbox has to stick out 15mm from the bellhose edge to center in the crank Sad
That's why we weld the gearboxes. Otherwise I would have been drawing an adapter plate a long time ago.
If you make a jig you can weld the gearboxes easy. Just make sure to mill them straight first. And DON'T center on the shaft.
(01-16-2015, 04:42 PM)raidaru brahs, I've been having this thought on my head for some time now, couldn't it be made an adapter plate with the holles for om606 engine and in such a way that the bmw gearbox can be welded directly to the plate without cutting the bellhousing? even if u cut a few places in the bmw bellhousing for puting the screws/strenghtening, but to be a standard adapter plate that u can't go wrong with the welding angles and stuff, I believe it should be possible, and the plate to be as thin as possible but still enough rigid Smile it would be best thing for om606 after the superpump Big Grin tremec&stuff is a dream for most of us, but a f...ing 5 spd from e39 530d is 400euros and full of them! People are dragracing 1000+nm on this boxes!!! Let's put our minds to work and sort this project out! And also the SMF that has to be machined to take the SACHS 765 PP . And everybody will be happy and burnin tyres, not cracking 3rd gears!!!
F.R.A.S
raidaru
01-17-2015, 02:40 AM #25
(01-16-2015, 05:00 PM)F.R.A.S I don't have the measurements for dual mass flywheels but for single mass this is not possible I'm afraid Sad
Then how about making let's say a 15mm adapter plate and a nice custom thicker flywheel?(even if needs design from scratch) Then you should be able to center the shaft in the custom flywheel. If u sort this thing out for once, then bmw g-box will be like puting a new mb gbox in the car,bolts on! And u can mass produce them afterwards, pretty sure they'll sell well Wink
raidaru
F.R.A.S
01-17-2015, 05:16 AM #26
For us it's no business in machining a flywheel but there are dual mass conversions out there for the Sprinter van that people use. Have to measure it but I still don't think it will work.
The newer BMW gearboxes also have short input shafts and the flywheel have to be really thick = heavy if not made off aluminum.
It's a lot easier to weld the gearbox and have a true Plug n Play gearbox Cool
I understand the idea though, just have to be realistic about it and I can't really see how it would work. Sorry mate.
(01-17-2015, 02:40 AM)raidaru Then how about making let's say a 15mm adapter plate and a nice custom thicker flywheel?(even if needs design from scratch) Then you should be able to center the shaft in the custom flywheel. If u sort this thing out for once, then bmw g-box will be like puting a new mb gbox in the car,bolts on! And u can mass produce them afterwards, pretty sure they'll sell well Wink
F.R.A.S
raidaru
01-17-2015, 12:53 PM #27
(01-17-2015, 05:16 AM)F.R.A.S For us it's no business in machining a flywheel but there are dual mass conversions out there for the Sprinter van that people use. Have to measure it but I still don't think it will work.
It's obvious a standard flywheel be it SMF or DMF won't fit with an adapter plate. As for a thick custom flywheel, there can be made a light design, doesn't need to be a full piece of iron 50kg heavy, u know what I mean. If adapter plate is 20mm, then custom flywheel needs to be 20mm thicker than OEM one. Then u could mass produce the flywheel and adapter plate as a kit working let's say with the SACHS 765 Smile As far as I know the 5spd from 530d e39 is the strongest, and also cheap, @400euros. It's just my opinion that if good design for parts, the rest is piece of cake, and people all @the world would benifit and you'll make some $$ too. Tongue
raidaru
F.R.A.S
01-17-2015, 01:09 PM #28
Hahaha, I'll think about it Tongue
(01-17-2015, 12:53 PM)raidaru It's obvious a standard flywheel be it SMF or DMF won't fit with an adapter plate. As for a thick custom flywheel, there can be made a light design, doesn't need to be a full piece of iron 50kg heavy, u know what I mean. If adapter plate is 20mm, then custom flywheel needs to be 20mm thicker than OEM one. Then u could mass produce the flywheel and adapter plate as a kit working let's say with the SACHS 765 Smile As far as I know the 5spd from 530d e39 is the strongest, and also cheap, @400euros. It's just my opinion that if good design for parts, the rest is piece of cake, and people all @the world would benifit and you'll make some $$ too. Tongue
F.R.A.S
CRD4x4
399
02-26-2015, 10:10 AM #29
Quick noob question off the top of my head:
- if the input shaft on dual mass type transmissions needs to protrude 15mm past their bellhousing in order to center on the 606 crank (as gathered from above), couldn't a solid flywheel be made to bolt up but without a hole in the center, instead having a machined "artifical crank surface" for the input shaft to be centered on?
This way, it seems to me, one could use an adapter plate for the bell-to-block and still have the input shaft reach a surface that'd act as the crank center hole.
As admitted above, I don't have indepth knowledge of this subject so please educate me if I'm way off.
CRD4x4
F.R.A.S
02-26-2015, 01:09 PM #30
(02-26-2015, 10:10 AM)CRD4x4 Quick noob question off the top of my head:
It's a good point. But see it this way. First of all the input shaft ends like 15-20mm before the edge of the bellhouse. Then you'll need a 10mm adapter plate that make it 30mm  from the edge of the bellhouse edge and 45mm from the crank. The single mass flywheel is about 10mm thick (thin) so you are still 35mm off.
And you have to custom make a flywheel instead of just machining one to spec. And if you do custom make a FW you can make it thick enough to work but those are already available on eBay for the Sprinter van. How much they protrude I have no idea but it might be something to work with if not going for the easy and proven way Smile
F.R.A.S
02-26-2015, 02:19 PM #31
My 4x4 labs om617 to chevy kit came with a pilot extender. Simple thing really. I think this pic of the extender is from JB3's Astro thread
[Image: pilotbearings.jpg]
I don't see why you couldn't make one out of just brass, with no bearing at all.
F.R.A.S
02-26-2015, 02:39 PM #32
Still need a super thick FW though Smile
F.R.A.S
02-26-2015, 02:50 PM #33
Oh yeah that too.
Blingfactory might have you covered there. I've got no idea why they made a FW so thick without adding a dual mass pilot. I'll have to compare the next (50th) time I pull my flywheel off.
Oh yeah that too.
swampmonkey
hx40 super
280
02-27-2015, 06:54 AM #34
(01-14-2015, 02:34 PM)F.R.A.S  People in Sweden witch you should know are going 1000whp with the old BMW miniature 5spd TDS-gearbox rated to 320Nm. The newer 6spd are tougher than that. And they work on all gears. In a Mercedes you have to do 1st, 2nd, 4th, 5th cause 3rd is made of glass.
/ F
the people ive talked to, with 1000hp and dragracing says the 6speed is weaker than the 5speed from the 530 bmw,
dont know the number of the gearbox, but the diameter of the ingoing "shaft" is as large as the 53dz..
strenght
525 5speed
530 6speed
530 5speed.
he went throu three (3!) 6speed 53dz untill he swapped to the 530 fivespeed, and now its the driveshafts, cardanshafts and everything else that doesnt hold up Tongue, the width of the drag tires about 2/3 of the car width.
but for a normal diesel the 6speed will probably hold up Wink
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
/ F
strenght
525 5speed
530 6speed
530 5speed.
daily driver
+ a few more.
mbturbo.com
