STD Tuning Drivetrain Flywheel bolts
Flywheel bolts
Flywheel bolts
Biocruzer
01-31-2015, 11:12 PM #1
Hi, I'm changing a 300D auto gearbox for a 4-speed 240D slopeback box with 240D bitznpieces. The auto flexplate bolts are too long (about 10mm) for the manual flywheel - are the manual bolts torque-to-yield? If not, what torque do I need, and can I safely use standard high tensile bolts. Is it the auto thing of 30-40 lb-ft + 90-100 degrees? Will HT bolts stand up to this? If they are t-t-y, what part no do I need to chase for the necessaries?
Cheers
Biocruzer
Cheers
Torkey
Dirty Diesel
220
01-31-2015, 11:46 PM #2
I did the sMe thing. There is a VW bolt that works great for this application. They are stretch bolts but I have successfully used them with just loc-tite. I'll dig up the part number and post the link. ( and they are way cheaper than the MB bolts)
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
Torkey
Dirty Diesel
220
02-01-2015, 11:18 AM #3
Here's a link to the ones we use. You need to get a star bit to drive them. I found one at AutoZone for cheap.
http://www.autohausaz.com/pn/N90539801
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
Biocruzer
02-02-2015, 05:37 AM #4
(02-01-2015, 11:18 AM)Torkey Here's a link to the ones we use. You need to get a star bit to drive them. I found one at AutoZone for cheap.
Thanks, Torkey. I'll give them a try.
Cheers
Biocruzer
Cheers
Druk
02-02-2015, 09:25 AM #5
The Haynes manual for the 300D gives 22lbft + 90deg for a standard flywheel bolts and 30lbft + 90deg for a dualmass.
iirc these bolts are metric extra fine and will be grade 12 high tensile.
This post was last modified: 02-02-2015, 10:38 AM by Druk.
Druk
wolverine
02-04-2015, 08:56 PM #6
I used ARP bolts. This is the set
http://arp-bolts.com/kits/ARPkit-detail....ordID=1216
You have to buy 2 kits though
wolverine
