STD Tuning Drivetrain How much power can a 722.6 handle?
Joystick
03-01-2015, 06:33 PM #1
Hello, i wounder if someone can ask me how much power/nm a 722.6 gearbox can handle? Can it handle more by adding this standalone controller box?
Joystick
erx
w202 om606
323
03-01-2015, 07:02 PM #2
Standalone controller will not make box handle more power. There are many different versions of 722.6, E300td and most of the engines which make torque under 330nm use box that is rated to 330nm. 270cdi, 320cdi and V8 models use stronger box which is rated to 580nm, some AMG boxes are rated to 900 and 1000nm but they are very rare.
erx
raidaru
03-02-2015, 04:13 PM #3
(03-01-2015, 07:02 PM)erx Standalone controller will not make box handle more power. There are many different versions of 722.6, E300td and most of the engines which make torque under 330nm use box that is rated to 330nm. 270cdi, 320cdi and V8 models use stronger box which is rated to 580nm, some AMG boxes are rated to 900 and 1000nm but they are very rare.
standalone controller can make them stronger, as it can run higher  pressures. Some more disc clutches in some of the packs will also add extra power for the box, and AMG solenoinds too.
raidaru
whipplem104
03-02-2015, 05:50 PM #4
As said it depends on the particular transmission. But basically if you are going to run large amounts of torque then start with a 580nm box.
The clutches are the limiting factor until you reach North of 1000lb/ft of torque. Then if a high stall converter and drag tires are used you will start to break input shafts. If you are not going to exceed 5-600lb/ft of torque then the clutches can handle it. Above that you will start to slip depending on use. Machining the pistons for additional clutches and some different clutch baskets can get you pretty much were you want.
The standalone can increase power handling a lot of any box. THe factory does not use the total available pressure in the valve body which the standalone can take advantage of. Increased shift firmness and holding pressures both.
whipplem104
erx
w202 om606
323
03-02-2015, 06:26 PM #5
722.6 has two pressure regulating solenoids, one is for modulating pressure and second for shift pressure, I belive they are both used for shifting. Or am I wrong? I mean if accelerating with full throttle without shifts then clutches are held by solenoid regulated pressure or constant line pressure?
This post was last modified: 03-02-2015, 06:50 PM by erx.
erx
whipplem104
03-02-2015, 07:46 PM #6
It is rather complicated in the way pressures are regulated. But they are both active during a shift. The modulating solenoids main function is to control the working pressure at the working pressure control valve, which all other pressures are derived. The shift pressure solenoid controls the shift pressure valve. This valve dictates the pressure applied to the clutches for a shift. Working pressure is applied to the clutches once the shift is over. The other function of the modulating solenoid is to control the overlap valve during a shift. This is to determine the rate at which the off coming clutch drains.
The working pressure can be reduced to the point that the supplied pressure to these and the supply pressure to both the solenoids can be lower as well. At this point the modulator solenoid can have an effect on the shift pressure as well. This is important for low pressures in achieving smooth light throttle shifts were the shift solenoid can cause to great of a change in the pressure one way or the other. You can use the modulator pressure to adjust the scale a little. But you have to be careful not to have to low of a shift pressure and to high of modulator. This will cause a bind or kick back into the previous gear.
whipplem104
Joystick
03-03-2015, 07:57 AM #7
It is an 722.6 from my 300tdt w210. Is it possible to change the clutch plates to some stronger ones? Or can i dit in more original plates? I do have some New original ones but i dont know if its space for more? Where can i buy stronger plates?
Joystick
erx
w202 om606
323
03-03-2015, 08:54 AM #8
I don't know what are the prices in Norway but I think easier and cheaper is to buy another box that is rated to 580nm and change only the bellhousing. But then you need standalone controller because stornger boxes have different gear ratios.
What car, what engine and what power we are talking about?
erx
whipplem104
03-03-2015, 09:08 AM #9
(03-03-2015, 07:57 AM)Joystick It is an 722.6 from my 300tdt w210. Is it possible to change the clutch plates to some stronger ones? Or can i dit in more original plates? I do have some New original ones but i dont know if its space for more? Where can i buy stronger plates?
1st you want to check the input shaft and see if it has a  bushing or needle roller bearing in the back end of it where the rear shaft slides in. If it has the bushing just get a newer transmission to start from. You can use your bellhousing and converter on what ever you get.
The factory friction material is very good and that is what I use on all my builds. If you want to add more frictions to a particular clutch pack there is really only so much you can do. There are different thickness steel plates on the double sided friction versions. You can typically get one more friction in by changing to the thinnest steel plates. You can also mill the pistons down for added clearance. Again one more friction.
Now for how the transmission was made. The most frictions by design were in the larger capacity transmissions. There will be 4 in b1, 6 in k1, 6 in k2, 5 in k3, and 4 in b2. I am skipping reverse of course. If you transmission did not come with these combinations then the baskets are different. Different heights. Differeent snap ring groove positions. Different pistons. Etc. The problem with changing the baskets is that most have gear sets on them and they are expensive. I do use the k3 from  the 900nm transmission.
Hope this helps.
whipplem104
Hope this helps.
Joystick
03-03-2015, 09:15 AM #10
Okay. Thanks for nice info. Will a gearbox from e55 v8 amg be bolt on om606?
Joystick
erx
w202 om606
323
03-03-2015, 09:26 AM #11
(03-03-2015, 09:15 AM)Joystick Okay. Thanks for nice info. Will a gearbox from e55 v8 amg be bolt on om606?
No, only 580nm box that will bolt on is from 270cdi, all others fit only when you change the bellhousing.
This post was last modified: 03-03-2015, 09:28 AM by erx.
erx
Joystick
03-03-2015, 11:46 AM #12
Okay, so a gearbox from 270 cdi facelift will be just bolt on? Bolt on and drive out again? Big Grin Sounds amazing!
Joystick
erx
w202 om606
323
03-03-2015, 11:50 AM #13
If you have w210 E300td with genuine transmission control then it will not work because 580nm box have different gear ratios and car will go limp mode. With standalone controller it doesn't matter. But yes, it should bolt on, maybe you only have to change the flexidisk flange but it's easy.
This post was last modified: 03-03-2015, 11:51 AM by erx.
erx
Joystick
03-03-2015, 01:32 PM #14
Okay. Where can I orden this standalone controller? And will a gearbox from 320cdi be the same?
Joystick
erx
w202 om606
323
03-03-2015, 01:49 PM #15
(03-03-2015, 01:32 PM)Joystick Okay. Where can I orden this standalone controller? And will a gearbox from 320cdi be the same?
Olefejer sells them. No, 320cdi have different bellhousing.
What power are we talking about?
erx
whipplem104
03-03-2015, 01:54 PM #16
Ole, or the PCS unit from myself.
whipplem104
Joystick
03-03-2015, 02:42 PM #17
To start with, around 400-450hp.
Joystick
Joystick
03-04-2015, 11:45 AM #18
Will a 722.634 gearbox handle that with ole's standalone
controller?
Joystick
controller?
erx
w202 om606
323
03-04-2015, 11:49 AM #19
(03-04-2015, 11:45 AM)Joystick Will a 722.634 gearbox handle that with ole's standalone
controller?
Yes, it's from 270cdi and if it's in good condition it will handle 600nm easily.
erx
controller?
Joystick
03-04-2015, 12:00 PM #20
Cool. Do i Need something else from it? Converter only? And how many NM do you think i will reach with 7,5mm pump, and a hx40 turbo? Looking for 400-450hp.
edit: is it something east i can do with the New gearbox to make it handle more power?
This post was last modified: 03-04-2015, 12:01 PM by Joystick.
Joystick
erx
w202 om606
323
03-04-2015, 12:11 PM #21
Maybe 700nm but it will hold that. Converter may not fit but then just use 300td one, no problem.
erx
Joystick
03-05-2015, 02:57 AM #22
Okay, by the way. do i Need to weld the bellhousing if i use gearbox from 320cdi w211? (Like you) , or is the bellhousing fastened with bolts only?
Joystick
erx
w202 om606
323
03-05-2015, 03:33 AM #23
Bolts only, in youtube there are a lot of videos about how to dismantle 722.6.
On last page here are some pictures https://docs.google.com/document/d/1_WiB...QHUNI/edit
This post was last modified: 03-05-2015, 03:35 AM by erx.
erx
Joystick
03-05-2015, 05:34 AM #24
Thanks for Nice reading! So i can actually use any 722.6 if i Just swap over bellhousing? (No welding?) for example a 320cdi box with 300tdt bellhousing and converter?
Joystick
erx
w202 om606
323
03-05-2015, 07:46 AM #25
No cutting, no welding. You can also use box from any V8 gasoline engine, 320cdi is only one option. The newer the better. Changing the bellhousing requires basic car engineer knowledges, basic tools and clean environment, nothing special.
erx
Joystick
03-05-2015, 08:45 AM #26
Okay, should mange to do that. A friend of mine have been overhauling these 722.6 boxes for 30 years! Is there any list over 722.6 boxes, with info of how much NM they can handle and wich car they come from? Would like to go one stage up from 270 cdi so i know i kan put the pedal to the metall any time :p dont Need a expensive 1200nm box but for example a 7-800nm box? What do you recommend then?
Joystick
Duncansport
03-05-2015, 09:26 AM #27
30 years? Wow who knew 1996 was so long ago :-P
Duncansport
Joystick
03-05-2015, 09:34 AM #28
Sorry not only 722.6, he started with overhauling 30 years ago :p
Joystick
Joystick
03-06-2015, 06:16 AM #29
(03-05-2015, 08:45 AM)Joystick Is there any list over 722.6 boxes, with info of how much NM they can handle and wich car they come from? Would like to go one stage up from 270 cdi so i know i kan put the pedal to the metall any time :p dont Need a expensive 1200nm box but for example a 7-800nm box? What do you recommend then?
Joystick
erx
w202 om606
323
03-06-2015, 07:27 AM #30
Some are here.
722.600 W 5 A 330 C230, E300, E320 202.023, 083, 210.020, 210.037, 237
722.601 W 5 A 330 E250 DIESEL 210.010, 210.610
722.602 W 5 A 330 SLK200, C200, E200, CLK200 170.435, 202.020, 080, 210.035, 235, 208.335, 435
722.603 W 5 A 330 C180, C220, E220, C200, E200 202.018, 078, 202.121, 182, 210.004, 202.122, 0180, 210.003
722.604 W 5 A 330 SL280, S280, C280 129.058, 140.028, 202.028
722.605 W 5 A 330 SLK230K, SL320, S320, C230K, E320, C200K, CLK200K, CLK230K, E200 170.447, 129.063, 140.032, 033, 202.024, 210.055, 202.025, 082, 208.345, 445, 208.347, 447, 210.045, 245
722.606 W 5 A 330 C280, E280, SL280, E280T 202.028, 089, 210.063, 129.059, 210.663
722.607 W 5 A 330 E320, CLK320, SL320 210.065, 265, 208.365, 129.064
722.608 W 5 A 330 S300 TURBO, E300 TURBO 140.135, 210.025, 225
722.612 W 5 A 330 C250 TURBO 202.128, 188
722.613 W 5 A 330 E290 TURBO 210.017, 217, 617
722.614 W 5 A 330 C220CDI, E220CDI 202.133, 193, 210.006, 206, 606
722.615 W 5 A 330 C200, E200, CLK200 202.081, 210.035, 235, 208.335, 435
722.616 W 5 A 330 SLK200K, SLK230K, C200K, CLK200K, E200K 170.444, 170.449, 202.087, 208.344, 444, 210.048, 248
722.617 W 5 A 330 S280 220.063
722.618 W 5 A 330 S320 220.065, 165
722.620 W 5 A 580 S500, SL500 140.050, 051, 070, 129.067
722.621 W 5 A 580 S600, SL600 140.056, 057, 076, 129.076
722.622 W 5 A 580 S420 140.042, 043, 063
722.623 W 5 A 580 E430, CLK430 210.070, 270, 208.370
722.624 W 5 A 580 SL500 129.068, 210.074, 274
722.625 W 5 A 580 E420 210.072, 272
722.626 W 5 A 580 E320CDI, S320CDI 210.026, 226, 220.026
722.627 W 5 A 580 E50 AMG 210.072
722.628 W 5 A 580 CL580 215.378
722.629 W 5 A 580 C36 AMG 202.028
722.631 W 5 A 580 E43 AMG 202.033, 093
722.632 W 5 A 580 S430 220.070, 170
722.633 W 5 A 580 S500 220.075, 175
722.634 W 5 A 580 E270 CDI 210.016, 216, 616
722.635 W 5 A 580 S500 220.075, 175
722.636 W 5 A 580 E55 AMG, CLK55 210.074, 274, 208.374
722.661 W 5 A 300 ML270 CDI 163.113
722.662 W 5 A 300 ML320 163.154
722.663 W 5 A 400 ML430 163.172
722.664 W 5 A 300 E320 4MATIC 210.082, 282
722.665 W 5 A 300 E280 4MATIC 210.081, 281
722.666 W 5 A 400 ML55 AMG 163.174
722.669 W 5 A 400 E430 4MATIC 210.083, 283
722.697 W 5 A 330 C250 TD 202.128, 1883
722.698 W 5 A 330 C240, E240 202
722.698 W 5 A 330 C240, E240 202.026, 086, 210.061, 261
722.699 W 5 A 330 C220CDI, E220CDI, E200CDI 202.193, 210.006, 206, 210.007
erx
Some are here.
whipplem104
03-06-2015, 09:14 AM #31
It is not that important what the rating is from Mercedes. What matters is the clutch pack layout. If you find a transmission that you are thinking about buying you should look it up in the EPC and see how many clutches are in each clutch pack. Other than that it is really a choice on gear ratios between the small nag and larg nag vs.
Most large nag transmissions come in v8 and v12 cars and therefore have more clutches but there are small nag transmissions that come with more as well. Of course what country you are in determines how easy it is to find certain versions. Here in the U.S. a v8 transmission is probably the most common.
whipplem104
DanielK
Big Plans, No Clue
98
03-06-2015, 10:07 AM #32
Do the bell housings bolt up to the OM603/OM606/M103/M104 bolt patterns? I keep coming across V12 and V8 cars and know I want to run a 722.6 one day.
[Image: FalkonSig.png]
DanielK
whipplem104
03-06-2015, 10:22 AM #33
You will need to get a bellhousing for a inline engine. All others are different.
whipplem104
DanielK
Big Plans, No Clue
98
03-06-2015, 10:47 AM #34
I'm assuming a 722.4 bellhousing won't bolt up. That makes things interesting. Hmm
DanielK
whipplem104
03-06-2015, 11:25 AM #35
The earlier transmissions do not have removable bellhousings. And the 722.6 it is part of the porting for the clutches etc. Only 722.6 parts are compatible.
whipplem104
DanielK
Big Plans, No Clue
98
03-06-2015, 11:49 AM #36
oh, derp. I'm scattered this morning.
I'm out of the Mercedes thought process. I blame the stupid BMW.
This post was last modified: 03-06-2015, 11:49 AM by DanielK.
DanielK
