STD Tuning Engine What to expect from an OM601?
Matej
03-07-2015, 02:10 AM #1
While searching for an OM606, I happened across an OM601 for quite cheap, so I decided to pick up to tinker with and learn about diesels.
I know it is not as popular to turbo and mod as the 5 and 6-cylinders, but I am curious if anyone happens to know what the limits of this engine are (assuming it is in good condition).
The only OM601 I could find online modded for bigger power is the guy on YouTube with the buggy, who claims to have dynoed at 365hp with an HX40 and 8mm elements (https://www.youtube.com/watch?v=M93735bgYvE), though I am not sure if the motor is stock internally or how long it will last/lasted.
What kind of power would you approximate could be had with an HX35/HE35 and 7.5mm elements? Would it be too much for the motor to handle reliably on stock internals? 7mm elements? I would be perfectly happy with 250-300hp.
Any input is appreciated.
Thank you.
This post was last modified: 03-07-2015, 02:13 AM by Matej.
Irony.cc
Matej
Thank you.
Irony.cc
F.R.A.S
03-07-2015, 03:32 AM #2
The only om601 worth tuning is the 2.3-liter turbodiesel version from the Vito van. Otherwise you have to machine the block for the oil squirters and change to turbo rods and pistons.
F.R.A.S
Matej
03-07-2015, 12:31 PM #3
This the 2.2 version, unfortunately. Does anything swap over from the OM603 turbodiesel? There is one at a local junkyard right now. If not, I guess I have a new paperweight. Smile
Irony.cc
Matej
Irony.cc
F.R.A.S
03-07-2015, 01:27 PM #4
Rods and pistons would be an easy swap if it was a 2-liter. Now the bore and stroke is different witch makes it hard for you. Buy a euro crank and sleeve the block to 87mm and you can run 250hp safe. But for more power you really need to machine the block for the oil squirters.
F.R.A.S
Matej
03-09-2015, 07:01 AM #5
Would anyone happen to be able to identify what OM601 intake manifold this is?
http://www.benzworld.org/forums/w201-190...ost8571473
[Image: 907193d1398343004-w201-engine-swap-2-0-2-4.jpg][Image: 907201d1398343004-w201-engine-swap-2-0-2-5.jpg]
[Image: 907185d1398343004-w201-engine-swap-2-0-2-3.jpg][Image: 907257d1398343376-w201-engine-swap-2-0-2-2.jpg]
The owner claims the engine is from a 2.3 Vito (OM601.970), but I was unable to confirm that any of the Vito motors came with such a manifold.
Someone in the thread also suggest that it could be a SsangYong Musso or SsangYong Korando manifold, which do in fact use the same plenum style, but the inlet pipe goes over the valve cover, similar to OM602 and OM603, not downwards as on the pictured manifold.
Thank you for any help.
Irony.cc
Matej
Irony.cc
Matej
03-09-2015, 07:03 AM #6
Someone in the thread also suggested that it could be a SsangYong Musso or SsangYong Korando manifold, which do in fact use the same plenum style, but the inlet pipe goes over the valve cover, similar to OM602 and OM603, not downwards as on the pictured manifold.
This is the SsangYong manifold.
[Image: ssangyong.musso.4cylinders.jpeg]
This post was last modified: 03-09-2015, 07:04 AM by Matej.
Irony.cc
Matej
Irony.cc
Duncansport
03-09-2015, 07:11 AM #7
Thats a 602 intake cut down
Duncansport
Matej
03-09-2015, 07:20 AM #8
Alright, thank you.
Initially I considered that it may be a modded 602 or 603 manifold, but I thought it looked too good compared to most custom jobs like that. Smile
Irony.cc
Matej
Alright, thank you.
Irony.cc
