Anyone made their own transmission adapter plate?
Several people have.. I believe there is a thread on here where someone made their own plate. Used some clear plastic or something to mock things up then replicated it with metal. Look through the threads, there is some info here. I have no experience with this process personally.
(03-10-2015, 12:00 PM)capflya Several people have.. I believe there is a thread on here where someone made their own plate. Used some clear plastic or something to mock things up then replicated it with metal. Look through the threads, there is some info here. I have no experience with this process personally.
What 3 transmissions are you planning to use?
Someone on here may be working on a solution already.
I've got an E21 & E60 bmw manual transmissions that I'm planning to mate to a 617 & 606, respectively, and neither has a ready-made plate available so I'm in the same boat.
Maybe we can collaborate.
(03-11-2015, 07:41 AM)CRD4x4 What 3 transmissions are you planning to use?
I'm learning too. No shame.
If I were going to use an auto trans I'd stick with what MB intended originally. It won't have 6 gears but it'll fit and can be upgraded internally to handle more torque.
If the trans gearing isn't ideal for your app then consider changinger the rear diff gearing to suit.
The main thing to look for (in my opinion) is a trans from an inline engine. Vee configured engined donors probably won't be helpful - unless they've already been adapted as oem (my Jeep Liberty has a 545RFE V8 auto mated to a inline 4 from the factory, so there are exceptions).
Good luck and don't hesitate to ask the forum for help!
