STD Tuning Engine Which (budget) brand gauges to you guys recommend?
xl.617.lx
Junkyard Dog
59
03-13-2015, 04:38 PM #1
Hi everyone,
Im ready to order the guages for my w123 build, I'm going to get a egt, emp, and boost gauge.  I want to get some decent gauges but I can't spend $1000 on three guages.  Are there any decent gauges out there for aound $100 each?  What brand if any would you guys recommend in that price range?  What gauges do you guys use?  I really hope my only option at the price isn't some Chinese garbage.
Any advise would be greatly appreciated as always, thanks guys!!
xl.617.lx
Hi everyone,
03-13-2015, 07:31 PM #2
$100 a piece should get you some nice autometers, or if your old school look into Stewart Warner's
wolverine
03-13-2015, 07:58 PM #3
An"emp" gauge would be completely unnecessary for a permanent install.  You can use your boost gauge or an old mechanical fuel pressure gauge for checking emp while tuning/tweaking/checking or what not.  But no need to constantly monitor it.
An EGT will be the most expensive (simply because of the circuitry involved).  And there's 1 million flavors of boost gauges out there, and they will all be perfectly fine for what your doing.  No need for laboratory grade data acquisition on our old diesel Benz's Smile
Look on Summit.  They should have about everything you need at the best prices probably.
wolverine
Mr_Robs
03-13-2015, 09:42 PM #4
Dont cheap out on the EGT one. A bad probe will break and destroy your turbo. I got my PPE one for about $165 shipped, its analog for the "old school" as some call it. I think analog is just much cleaner in the W124 than the boy racer digital stuff.
Check out some pics of the gauges in my build thread
http://www.superturbodiesel.com/std/show...p?tid=6272
Mr_Robs
Matej
03-13-2015, 10:08 PM #5
SpeedHut gauges are supposed to be good. Though they are generally about 160-180$ per gauge.
This fellow uses them, and he builds some of the nicest custom gauge pods and clusters out there:
http://www.broadfieldcustoms.com/speedhut-gauges/
This post was last modified: 03-13-2015, 10:10 PM by Matej.
Irony.cc
Matej
Irony.cc
xl.617.lx
Junkyard Dog
59
03-13-2015, 11:19 PM #6
(03-13-2015, 07:31 PM)MFSuper90 $100 a piece should get you some nice autometers, or if your old school look into Stewart Warner's
(03-13-2015, 07:58 PM)wolverine An"emp" gauge would be completely unnecessary for a permanent install.  You can use your boost gauge or an old mechanical fuel pressure gauge for checking emp while tuning/tweaking/checking or what not.  But no need to constantly monitor it.
(03-13-2015, 09:42 PM)Mr_Robs Dont cheap out on the EGT one. A bad probe will break and destroy your turbo. I got my PPE one for about $165 shipped, its analog for the "old school" as some call it. I think analog is just much cleaner in the W124 than the boy racer digital stuff.
(03-13-2015, 10:08 PM)Matej SpeedHut gauges are supposed to be good. Though they are generally about 160-180$ per gauge.
Right on guys!
Thanks for all the information and advise, I REALLY appreciate it!!!
Time to do a little shopping, lol!
xl.617.lx
Right on guys!
xl.617.lx
Junkyard Dog
59
03-13-2015, 11:28 PM #7
Wow, nice build!!
How's it coming along, I'd love to check it out some time!
I used to live in San Jose, downtown on 2nd.  Im in the east bay now.
xl.617.lx
Wow, nice build!!
[486]
03-13-2015, 11:34 PM #8
Both my pyros were used and dirt cheap, around ten bucks apiece for an aircraft one out of a helicopter, and one from a kenworth made by isspro.
The probes I use are normal water heater thermocouples.
[486]
matfield
03-14-2015, 07:22 AM #9
I used VDO vision. Great quality and very reasonably priced.
http://www.egauges.com/VDO-Vision-Black-.../21006.htm
Hope that helps
Mat
matfield
Hope that helps
Mat
CRD4x4
CompoundSuperTurboDiesel4x4!
399
03-14-2015, 08:46 AM #12
I just got a set of New South Performance analog gauges (boost, oil temp, oil pressure) which are a "perfect match to VW/Audi gauge colors".
I got then used for $100 total (not each) from a part-out and figure my vehicles are used, engines used, why not buy used gauges? They can be tested with a multimeter beforehand.
$$ I WTB a matching EGT gauge $$
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
03-14-2015, 09:10 AM #13
Auber iinstruments has a large selection of reasonably priced thermocouples and bungs, and some simple, cheap digital gauges that can be discretely installed in a 123.
My favorite is the Idash. It can meet your needs for about 350, and still have massive expandability. I'm pinching my pennies for one now.
mach4
R107 Diesel
35
03-14-2015, 09:06 PM #14
 I wanted to have a complete set of engine gauges for my project vehicle so I built an Arduino microcontroller based system that captures oil temp, trans temp, EGT, boost, vacuum, intake temp, voltage and fuel pressure. The Arduino transmits the data to a steering wheel mounted tablet wirelessly over bluetooth to provide several display screen options.
[Image: 126412d1418926691-engine-instrumentation...uges-d.jpg]
The Arduino parts cost about $25, the tablet was $65 and the sensors were about $60. Obviously there is a lot of time involved to engineer and program the system but it's pretty cost effective for what it does... and the tablet does double duty as a nav computer and a HUD trip computer.
mach4
03-14-2015, 09:17 PM #15
I wish I knew about using arduino boards. You can do lots of awesome stuff with it!
And x2 on the egt gauge. Everyone I know (Bedsides myself) that has a glowshift pyro has stopped working.
Joystick
03-15-2015, 03:13 AM #16
(03-14-2015, 09:06 PM)mach4  I wanted to have a complete set of engine gauges for my project vehicle so I built an Arduino microcontroller based system that captures oil temp, trans temp, EGT, boost, vacuum, intake temp, voltage and fuel pressure. The Arduino transmits the data to a steering wheel mounted tablet wirelessly over bluetooth to provide several display screen options.
Do you want to make some and sell them?
Joystick
mach4
R107 Diesel
35
03-15-2015, 06:54 AM #17
(03-15-2015, 03:13 AM)Joystick Do you want to make some and sell them?
I thought about it, but there is just no way - everything is just too custom. If you add or delete just one sensor, both the Arduino and the Android have to be reprogrammed. And then there are the sensor mounts which are also custom. And there is no guarantee that the bluetooth would work with a particular tablet (had big problems with an HTC phone I started with). And of course many would want iPhone or iPad apps. And providing support would be a nightmare. Not to mention that the market is just too small to support the effort. And finally there are excellent systems for providing similar functionality on OBD equipped cars which makes the market even smaller.
If someone were inclined to embark on a similar project I'd be happy to share my design process, sensor choices, code processes and other issues.
mach4
erx
w202 om606
323
03-15-2015, 04:18 PM #18
Is someone using wideband lambda sensor and AFR gauge on STD car? I was just wondering if there's any reason I should consider buying one or just stay with EGT gauge only.
This post was last modified: 03-15-2015, 06:04 PM by erx.
erx
xl.617.lx
Junkyard Dog
59
03-16-2015, 01:20 AM #19
Holy shit!!
Thats too nice, well done!!!
xl.617.lx
Holy shit!!
03-16-2015, 08:48 AM #20
This is similar to iDash. iDash addresses some of issues you mentioned. It works will all operating systems, and uses WiFi. Got accelerometers too. It's really a great bargain if you utilize 25% of it's capability.
