STD Tuning Engine P1223 engine failt code w210 300tdt - found the chip!
Joystick
03-15-2015, 08:20 AM #1
Hello. Sometimes when im out driving, and flooring the pedal - the electronics cuts off my pedal and the epc lamp shows up. After this, it runs just great, but it can sometimes cut my pedal again. I read out the code P1223 from the engine unit, and it says: "Fuel rack travel sensor or slide valve posistion sensor Y23/1|1.
In the start, i had some more faultcodes, but i deleted everything and did a testdrive and the lamp showed up again. The P1223 code whas then showin. Not as an actual fault code, but stored. It was also stored:
-P1220 - Fuel metering control Y23/1
-P1470 - Intake preassure or boost control
It is alot of black smoke from the exhaust when flooring the pedal, no oil consumption, and it smells diesel. Anyone know anything about this fault code?
Thanks.
This post was last modified: 03-15-2015, 11:30 AM by Joystick.
Joystick
Thanks.
Joystick
03-15-2015, 09:54 AM #2
One more thing. The previous owner said the car was chipped, and that there was around 220hp. Does anyone know where they store a chip on these cars? Would like to try to remove that shit, but i have no idea where they can put this stuff.
UPDATE:
I think i found this. Would it do any harm to try to turn on that blue wheel? Or should i just remove the shit and connect the wires as original?
[Image: 20150315_160638_zpsvkmz0tsy.jpg]
You can absolutely see that there have been someone here.
[Image: 20150315_160657_zpsjsvekqsp.jpg]
And here is the blue wheel i talked about. Can this be a type of setting? And that they did it wrong?
[Image: 20150315_160712_zpsyjdq6rep.jpg]
This post was last modified: 03-15-2015, 11:28 AM by Joystick.
Joystick
UPDATE:
