vacuum on m pump
vacuum on m pump
what do you use to control vacuum stop on m pump
(03-22-2015, 11:59 AM)gary andrews what do you use to control vacuum stop on m pump
thanks Petar
put one of those valves on and works the first time them when i go to start it again it seems like the vacuum stops the pump from shutting ,am i missing some thing here
(04-04-2015, 01:58 PM)gary andrews put one of those valves on and works the first time them when i go to start it again it seems like the vacuum stops the pump from shutting ,am i missing some thing here
