Which ASD pump should I choose?
Hello everybody,
sometime ago I obtained an ASD diff and I intend to fit it into S124 chassis with (for now) stock OM606.910 and 722.435. I read the 'tutorial' about ASD retrofit and was thinking if there is anything against simply using a stock tandem pump from factory fitted ASD vehicle (with a few [electro]hydraulic valves) to engage the clutch packs whenever I wish? Unless somebody tells me it can't be done I want to try this:]
So to the question, which of the following pumps should I choose?
ZF? http://imageshack.com/a/img661/2301/f36yC9.gif
LuK? http://imageshack.com/a/img540/9272/EYh2qb.gif
Vickers? http://imageshack.com/a/img537/6057/J2Ykyj.gif
I'll add that my power steering pump is LuK and it is supposed to pump 110 bar (or so I remember).
Any comment/advice will be greatly appreciated.
Regards, CoTT.
