VGT, stock hybrid or other? Help with which turbo setup
Hi all,
My E300 sleeper project will be requiring more power in the coming years, I will be upgrading to 8mm elements so that the fueling is there to support any power level I want to go with, the main question is around which turbo would work best for my goals.
I will be looking to keep the stock part electric fuel pump (but with uprated elements etc), I will be upgrading the 722.6 box as well at some point, here are a few slightly different criteria that probably aren't done as much:
I am planning to keep the stock part electric pump
I am planning to keep the stock rev limiter (at 5.5kish I believe?)
I am planning to be running a stock ECU (although might try a piggyback) - will be running various resistors on sensors as well
I am planning to keep below the max boost that the ECU is happy with before it throws a code
I am looking for a modest level of power probably up to 400bhp.
I will be keeping it with a simple single turbo
I will be using the car for drag racing, however I have found that if there is too much power then the power can't be actually put down to the road, it just spins up the tyres or the autobox flares.
This will also mean that I will be looking for a setup which allows quite a large power band rather than a large spike of power near the end of the rev range.
I am aware that the stock turbo is 'ok' for stock and slightly higher than stock power, however runs out of puff at higher power levels when adding additional fueling.
Here are the options I thought about:
well , nothing of what u described will put u near 400mark except the 8mm element , but not in that pump.
if u want to be conservative on the matter, go after the 8mm element fit them in the pump , find a good remap and hit the road.
Depending on how the pump will perform , u may end up upgrading the turbo .
lets see , those EDC pumps dont have REV limiter, the ECU does, and it does cause there are one of the RPM sensor wich s limited to 5500RPM, basically it will be very dificult to REV past the 5500 pulling.
and diesels dont deliver mutch power at high revs, the torque curve peaks at 3000RPM and after 4500 most start to drop. Common Rail designs very hard achieve that.
the 722.6 will hold 1000nm and 700hp. but in the end for a 400hp 600nm engine u want to be mechanichal regarding pump and gear box.
wich leave u with the clutch issue.
722.6 very dificultly will be able to run with the mech pump. so..... da da da ....
back to beginings, element swap, ecu remap, exaust pipe, egr out of business, turbo try the 2359V will bolt in maybe u can control it with the ecu, if not i´ll teach how to make it mechanichal.
regards.
(05-12-2015, 01:32 PM)barrote well , nothing of what u described will put u near 400mark except the 8mm element , but not in that pump.Hi again, just trying to get this right, I know for a fact the stock turbo will be no where near capable of supporting much over 200bhp so that's a definite upgrade needed, I was also looking at the Holset HY53 which should flow a fair amount of air.
regards.
regards.
(05-13-2015, 12:09 AM)AlanMcR The 722.6 that came with your E300 was rated for 330NM. It can be reworked to support more power, and I don't think that is actually all that difficult. But it is a complete teardown to replace the friction surfaces.
he he,
well i dont think u need any advice, since u know such a lot of things about ECU`s and resistors , and adding extra fuel at the end of injection, and suporting VNT`s . REV limiters and all that......
what i can bet with u is that , with the improvements u want to do u´ll never reach the 400hp.
is your Money so...... good luck
(05-13-2015, 05:14 AM)barrote he he,
some coments can be as constructive as they are , or as destructive as they are.
For me i´m good , i just disliked when u start talking about things that are not done that way, after i writed a good tip for u.
if your question is: what turbo will be able to produce 400HP ? u can use those holset 35 and above family, or from GT28 on.
if your question is: what turbo will be good for 8mm element? any one will do!!!! that depend on how much fuel u can take out from your pump. and a EDC direct swap it wont be much maybe 90cc and for that the kkk24 will do the trick , and belive me it will blow more than 200hp. a lot more.
tryed things are all over the fórum, americans like holsets, me and my friends like VNT from garret, the russians like borg warner, well again all depend on how much fuel u can put out.
(05-13-2015, 01:32 PM)barrote some coments can be as constructive as they are , or as destructive as they are.
stock EDC for 604/5/6 is tuned at 62 to 65 cc turbo pressure above 1.2 bar. stock configuration.
601/2/3 pumps for turbo engines have between 42 to 45 with alda at max, usually above 800KPA
installing wider elements witout the tuning in the governor for mech pumps will increase fueling by the diff in diameter only, and that maybe 10% from 5.5 to 6. 5.5 to 7.5 25% about that much, more less.
installing wider elements in the EDC pump without proper ECU tuning will have the same efect. 65cc * 25% = more less 90cc to 100cc
that is good for 50hp cylinder, and that your curent turbo will be enough.
the trick is to make the EDC or other able to put out 150CC that will be good for more than 70hp Cylinder your 400hp above.
for those turbos u should ask to the fins and swedes , they are doing that.
(05-13-2015, 01:57 PM)barrote stock EDC for 604/5/6 is tuned at 62 to 65 cc turbo pressure above 1.2 bar. stock configuration.
HY35 will is not a VGT/VNT turbo, it is a fixed geometry exhaust housing that is only 9cm. From what I have read from the 606 tuners, a hy35 holds way to much backpressure on the engine. HX35 is a better option from what I see
But then again, I haven't built a om606. So what do I know
(05-13-2015, 06:19 PM)aaa The modified pumps usually have greater than normal rack travel, so that is one reason leaving your ECU as is will result it in it not using the pump's full output.
(05-14-2015, 02:03 AM)m1tchGoing from 6mm to 7mm elements (with no other changes) would, in theory deliver ~36% more fuel for any particular rack position.(05-13-2015, 06:19 PM)aaa The modified pumps usually have greater than normal rack travel, so that is one reason leaving your ECU as is will result it in it not using the pump's full output.
Could this be countered by having large elements so that although the total rack travel might be less the fuel delivered would be slightly higher to counter it?
Also, if the rack sensor output was showing slightly less than the actual position, would this mean that the ECU would move the rack slightly more therefore getting additional fueling anyway?
(05-14-2015, 01:00 PM)AlanMcR(05-14-2015, 02:03 AM)m1tchGoing from 6mm to 7mm elements (with no other changes) would, in theory deliver ~36% more fuel for any particular rack position.(05-13-2015, 06:19 PM)aaa The modified pumps usually have greater than normal rack travel, so that is one reason leaving your ECU as is will result it in it not using the pump's full output.
And, yes, if you attenuate the rack position sensor then the ECU will move the rack out further to get the position value that it is was trying for. That is what the "resistor fix' does on the OM606 ECU. I tried this and it definitely adds noticeable power. Unfortunately the extra fuel is delivered late in the combustion cycle and is not all that efficiently burned. Also, the ECU doesn't know it is burning more fuel and thus it doesn't turn up the boost to match.
sorry to bother mitch,
do have any problem in remap the curent ECU u have?
the problem with those electric/mechanichal cars/engines u talk about is that or the electronics dont keep the mechanichal mods or the oposite.
what usually people do , is to avoit that mech/electro gap they move to pure electronics wich in a 606 is not posible. or they move in pure mechanichal, wich i dont see any point.
well most are not very aware how a 605/6 engine works. first of all injection time and duration is mechanichal, injection advance is also mechanichal. the electric part is the governor and rack actuator wich instead of a cable and masses is a electroactuator and a position sensor, governing function is thru the ECU based on MAF,RPM, some boost press as comparisson to MAF. it runs also the auto trans and EGR functions, witch otherwise would be a mixt of electrologic and vac actuators and hardware.
i know people wich maped the ECU just to run the engine. they had succes, not 100% but some success.
mater of speach u can´t tune with great success your 606 with EDC pump without a ECU tunner .
the turbo , u can put it to operate pure mechanichal even if it is VNT. for instance the 606 engine uses a turbo just to compensate absolute pressure, this means that most WG actuators are intended to provide 1.2 /1.3 BAR boost. well your current turbo will be able to produce at least 1.6/1.7 bar without having to much EGP, something that can´t be avoided since it is a WG turbo.
on the other hand the VNT types were developed to produce higher amounts of boost in a early RPM , and they have inerently less EGP.
but there are limits, and they dont work very well at high RPM unless they are prepared to do that.
about the EDC pump if u buy a 7.5 mm installation from dieselmeken, phisically that pump will be able to inject 140cc at 4.5 volts, and have the correct rack position for idle/ and constant RPM(steet driving) purposes. after that u just need the ECU tunner in order to use the mechanichal potential of what u acquired.
so, u have a lot of work to be done before changig the turbo. what i use to do is put the engine to smoke and then is time for new bigger turbine. in my opinion if you are able to put your engine somoking like hell, then is time for a new bigger turbine.
regards
(05-15-2015, 03:56 AM)barrote sorry to bother mitch,
regards
regards
(05-17-2015, 05:08 AM)barrote the thing u mention with the feasibility of changing Your ECU ROM , the ECU are interchangeable between cars , and the ROM can be rewritten.
i dont know how they do it, but i have seen it.
regards.
regards.
Update: Just bought an OM603 mechanical pump, will look to get this upgraded and fitted over the next couple of years, will be running the stock EDC pump for a while though - will be interesting to see how much power I can get out of it when its coupled with water/meth injection as well.
(05-20-2015, 01:47 PM)barrote well, i see your point with the chip dada thing.
if u want , i can assemble your 603 pump to have a lot of fuel, more than u can ever burn without highly moded engine))
ps: try to buy the right pump
hey man , i dont know , i´m used to old cars....
the pump numbers , they are part numbers, what do u want to do with that pump? there´s nothing u can do besides take it to a diesel shop/fellow to have it rebuilt. and i bet 99,9 % of the diesel shops wont do what u want.
and some fellow´s like me do want nothing to do with a EDC pump.
send it to sweden they know what to do.
regards
(05-21-2015, 01:18 PM)barrote hey man , i dont know , i´m used to old cars....
regards
regards
M pumps from 617 difer from M pumps in 60X, in cam relating issues, no other diff in the main body, EDC pumps have the same cam size.
Governors , they do differ and for instance a Governor from a 603Td wich can be a RS158, worth f%$/&% nothing compared to a RS201 usually found in the 606N/A.
thats what i have experiece on.
